View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 91 of 376 FirstFirst ... 4181828384858687888990919293949596979899100101141191 ... LastLast
Results 901 to 910 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #901
    Dec 2006
    BROOKLYN NY
    john it works
  2. #902
    Constant Bitrate Bump's Avatar
    Nov 2004
    Chambersburg, PA
    Quote Originally Posted by meisner View Post
    Also, is Rip CD working yet? Cause it's not in my setup. When I click on rip cd, I just get a loooonnnnnggg pause...then nothing.
    Steve
    cd ripper is a plug-in you have to get and in stall in your RR folder. It is not in the skin.
    get it here CD Ripper plug-in
  3. #903
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by shot598 View Post
    john it works
    Could you explain just a little bit? Were you having the CPU isssues, and you followed the instructions about double clicking the Photo.exe and it cleared up the problem? Or all was well for you since installing it?
    As for the CDRip, there is a FAQ at the top of the main page of the forums. The skin only has, just that, a skin for it. You have to configure it to get it to work correctly.
    NOTE: If the loading...... screen stays there for more than a few seconds, just click it. The entire page is a huge "Back to Menu" button.
    My Fiero Build Thread
  4. #904
    Dec 2006
    Quote Originally Posted by klundy View Post
    No, I'm not that smart
    They work just fine in Digital Blue FX - I can provide screen shots later. All from the same RR install.
    Unless ... is exectbl.ini per skin?
    Edit: ahh, your comment that you couldn't find the commands made me search. It is a plugin, and I need to register the plugin on your new menu.skin Nice little plugin
    http://www.mp3car.com/vbulletin/rr-p...op-carpcs.html
    Kevin
    Boy, it sure helps when you tell a skin to use a plugin before trying to use variables from the plugin
    John, since you mentiond hidden buttons you intended to clean up, I think you have one on menu2 for the valentine?
    Also, this is a REAL tiny nit pick - the size you have defined for bdlogo between menu and menu2 changes, which causes the logo to change visibly. I made mine equivalent, and I think it makes the screen change more professional looking.
    Now I just need a way to track my changes, so when you make your changes I can get them all back in
    Keep up the good work! Might soon be time for more beer money.
  5. #905
    Dec 2006
    BROOKLYN NY
    when i installed 2.1 the cpu is at a 100 if I tried to touch any of the buttons nothing happen.
  6. #906
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, Now I am confused, but that doesn't take too much
    Just a couple posts back you said "It Works". Now you say that is is locked at 100% CPU?
  7. #907
    Jan 2007
    Columbus, OH
    John, to clarify my situation. When I used 2.1 it was having the flash issue at 100% I downgraded it to 2.0 and it worked, obviously due to no flash logo. Sorry for not explaining I still had the old installer and I downgraded it in order to be use the PC.
  8. #908
    Dec 2006
    BROOKLYN NY
    no that was the problem i was having before u told me what to do
  9. #909
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    And doing that fixed your problem then?
  10. #910
    Dec 2006
    BROOKLYN NY
    yes sir
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
