View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 95 of 376 FirstFirst ... 45858687888990919293949596979899100101102103104105145195 ... LastLast
Results 941 to 950 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #941
    Jun 2002
    Virginia
    Thanks for all the hard work and the fast updates, John. More beer money sent!
    A couple of issues/questions:
    1. The XM skin shows up with the old blue color regardless of the background chosen. Are you planning on making that skin transparent also?
    2. Are you going to release the revised XM favorites PSD so we can change the icons around?
    3. I see that Guino has added Firefox zoom capabilities to RR. It sure would be nice if we could zoom in and out through the browser skin.
  2. #942
    Constant Bitrate DeadlyAP1's Avatar
    Aug 2005
    MA
    Is there some code that I need to put into a file for the GPS stats and compass to work? I am sure it is in this post somewhere, but sixty something pages is alot to read. I fell behind in this post when I went on vacation. Right now, the GPS stats and compass are doing nothing. thanks
  3. #943
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Deadly, do you have a port splitter running?
    http://www.mp3car.com/wiki/index.php/GPS_Splitter
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #944
    Aug 2005
    MA
    Quote Originally Posted by muldrick View Post
    Yes, Xport.
  5. #945
    Jun 2004
    South-Central PA
    Hmmm, can't help further...yet.
    I was just actually starting to mess with this, and I can't find the Xport files. Where are they?
    http://curioustech.home.insightbb.com/xport.html: Object not found!
  6. #946
    Aug 2005
    MA
    The link I had isn't working now. Don't know where to get it anyomre. If you get stuck, let me know and I will pull it out of my cars machine and post it.
  7. #947
    Jun 2002
    Virginia
    Quote Originally Posted by DeadlyAP1 View Post
    Yes, Xport.
    Xport is attached.
    Attached Files Attached Files
  8. #948
    Aug 2005
    MA
    thanks, saved a copy just in case.
  9. #949
    Jun 2002
    Virginia
    It sounds like Xport isn't running or you have not set things up properly. Try this:
    1. Download Xport3 (previous post).
    2. Open iGuidance outside of RR. Go to Tools/GPS Options/Autodetect. This will tell you what port your GPS Receiver is using.
    3. Load Xport3. Go to the input section and choose the com port determined in 2 above. Then go to the output section. In the first output block choose any available com port from the list. Remember the number because it will be the com port setting that you use in iGuidance. In the second output block pick any other available com port. Remember the number because this will be the GPS setting that you choose in RRConfig. Click the enable service box. Leave Xport running (you should include Xport.exe in your startup folder so it always loads upon startup).
    4. Open iGuidance outside of RR. Go to tools/GPS options/Com Port. Designate the com port number that you chose in the first output box of Xport. Exit iGuidance.
    5. Open RRConfig. Hit the GPS tab and in the box labeled "GPS Port" type in the number of the com port that you chose in the second output box of Xport. Save and exit RRConfig.
    In a typical scenario you should now be able to run iGuidance and the speedo in any RR skin. I have found Xport to be finicky at times so you may have to open Xport and just make sure it is shown as enabled and everything seems to be working. If Xport is receiving the information from your GPS receiver the NMEA data will be shown scrolling at the bottom.
  10. #950
    Low Bitrate jjnit's Avatar
    Feb 2007
    Quote Originally Posted by kbreeden View Post
    Just an FYI - iGuidance does not play nice with port numbers higher than 9... it will forget the settings every time if you set it higher. Took me a few weeks to find a thread that had the answer to that problem
    Example - my setup now is as follows, where before I had iG on like port 13, which does not work
    In:com2
    Out-08: RR
    Out-09: iGuidance
    Out-10: Delorme SA (so I can see more POI's)
    Out-11: GPStracker
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
