View Poll Results: What GPS Program do you use?
Voters
1065. You may not vote on this poll
  • iGuidance
    607 57.00%
  • MapPoint
    56 5.26%
  • Destinator
    185 17.37%
  • Streets & Trips
    90 8.45%
  • Other
    127 11.92%
Page 96 of 376 FirstFirst ... 468687888990919293949596979899100101102103104105106146196 ... LastLast
Results 951 to 960 of 3760
Thread: Digital FX 2.0 Transparent Released
  1. #951
    Constant Bitrate morris_the_cat's Avatar
    Aug 2006
    Vancouver
    Quote Originally Posted by morris_the_cat View Post
    Can do tomorrow. Not going to the car anymore tonight.
    Ok John, I entered the code & it had no problems. Actually, I think iguidance started up even quicker than normal. No momentary blank screens so far either. Cool
    2001 PT Cuiser
    VoomPC with 1.5Ghz C7
    M2 power supply
    in dash slim tray dvd drive
    DWW-750FM c/w 7" USB touchscreen,AM/FM, 4x45W amp
    See my install here
  2. #952
    Jun 2002
    Virginia
    Are the POIs in Delorme pretty good?
  3. #953
    Low Bitrate jjnit's Avatar
    Feb 2007
    Quote Originally Posted by kbreeden View Post
    Helluva lot better than iG3
    No better than most other programs, I just happened to have a "copy" laying around so I use it. MS Streets probably has as good of a DB.
    There's a project somewhere on this forum to import POI's from the Lexus system CD as it has the most one of the most complete POI databases known to cars - or to me at least It has not gotten very far though, as iG's data files are weird and no one seems to have figured out how to import items into it.
    Sucks - iG is the best touchscreen/car friendly mapping software I have ever seen or used.
  4. #954
    Apr 2005
    Does your guys' GPS Weather work? When I press it I get nothing. But the other weather locations work. I have my GPS split to the Skin and to IG. Any ideas?
  5. #955
    Dec 2006
    In a typical scenario you should now be able to run iGuidance and the speedo in any RR skin. I have found Xport to be finicky at times so you may have to open Xport and just make sure it is shown as enabled and everything seems to be working. If Xport is receiving the information from your GPS receiver the NMEA data will be shown scrolling at the bottom.
    Yes, I have that every now and then. Would like to imbed/open it in a window of FX. Have you tried that? Know the window name?
  6. #956
    Dec 2006
    Quote Originally Posted by wsudu View Post
    On a very similar note (I suspect it's the same problem source), on my GPS Stats screen, it's not displaying the city,state,zip?
    Kevin
  7. #957
    Jun 2002
    Virginia
    Quote Originally Posted by klundy View Post
    I've only occassionally had trouble with XPort when setting it up. Once setup and working it has been flawless. I have it in my startup folder so it's always working and I have no problems. Accordingly, I've found no need to embed it.
  8. #958
    Jun 2002
    Virginia
    My experience is the same as yours.
  9. #959
    Apr 2005
    Well, I know that the skin is getting the info because the gauges work and the compass works. I wasn't for sure if it got the location info from IG or just from the GPS direct.
  10. #960
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    OK, on XPort I have input at Com3, Output Com 2 and Com 6. Run IG as alone, set port to Com 2, works fine.
    RRConfig, set port to Com 6, compass works fine.
    For some reason IG inside of RR won't work. IG works fine outside of RR.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. Artec T14A Mini USB 2.0 Digital HD TV Tuner
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 12-02-2006, 01:02 AM
