I have loaded DFX 2.11 on a desktop with iG 3.0 and a car PC with iG 3.1.
I get the iG GPS display with two vertical columns of icons with iG 3.0 and a full screen GPS (no DFX icons) with iG 3.1. I understand that this problem will not be fixed until someone modifies (reshacks?) iG 3.1. Does anyone have any idea when this might happen? I have searched RR forum, as suggested, but find no clue as to how reshack accomplishes this task. Is there anyway to minimize the GPS display so as to access audio icons when using iG3.1?
When I attempt to use Auto Config with either ig 3.0 or 3.1, I lock up the system. I believe that I read earlier in the forum that this is a known problem. Can anyone tell me if there is a fix available? I note in iGOptions.skin that most of the paths are wrong for my system and are hard-wired for a c: drive installation. Would correcting these paths cure the problem?
When I return from using GAS in iG 3.0, there is no GPS display until I hit a gps icon. I believe that others have mentioned this, also. I am unable to test this with iG3.1.
LinkBack URL
About LinkBacks
