Page 16 of 92 FirstFirst ... 6789101112131415161718192021222324252666 ... LastLast
Results 151 to 160 of 919
Thread: Freedom Ultimate (Worklog)
  1. #151
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by CdRsKuLL View Post
    bugs
    1. no there not, repeat on the bottom, shuffle on the top..
    I'd have said the other way round my self with the broken lines reflecting diffrent tracks and the solid arrows looping reflecting the full play list repeat mode.....
    BTW - Another bug ( although dependent on what you just said I don't know if your going to look at it yet ).
    If you have the speedo on and come out of hibernate the whole skin does not refresh / do any thing until its picked up satalights which may be up to 45 seconds. The skin is not hung as you can press the exit button and the sound can be heard and you can see its been pressed.
    Terran
  2. #152
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by ccsnet View Post
    Terran
    Hi m8, this doesnt happen to me, I would suggest this is down to your gps device, when I come out of hibernation everything is working fine straightaway I can got audio etc.. no probs. I'm assuming the screen isnt updating as your gps device isnt locked and after 45 seconds it gets a lock and rr starts to post its info, does this make sense ?
    anyone else having this problem at all ?
    as for the icons..
    I would say the top one, the one with the arrows going round is for the shuffle as they jump down the listing, then back up again, the arrows going down and up.. the repeat.. are --- each track in turn, then an arrow going from the last track to the first track.. ie.. repeat
    cheers
    CdR
  3. #153
    Jan 2003
    I think its when the GPS is locking on to satilights from cold. My boot up takes longer than hibernation so the device has time to get its act together.
    I also cut power completly to it through the M2 on the first jumper setting ( 5/45secs off ) rather than the default ( 5/2hrs ) which is the second jumper setting to get rid of a problem with my touch screen I found recently. This second setting ment that the GPS was getting power for some time and therefore did not need to re-lock and as far as the skin went this issue was not there.... does that help ?
    In any case to get round it my suggestion would be to make the sat indicator be indipendant of the main skin for those reasons.
    Terran
  4. #154
    Feb 2004
    Manchester
    Hi m8, when you say the sat indicator to be independant of the whole skin ? dont quite know what you mean.. all it does is show the level of the GPSSAT indicator given out by RR.. ie... code wise is
    _root.satlev.lev.gotoAndStop(_root.GPSSAT);
    so in satlev.lev sprite, on frame 1 its shows gps zero, on frame 12 it shows gps full, so all its doing is going to the value of GPSSAT, this in no way would lock the skin up and does this once a second as thats the speed rr updates this variable, so if your getting a problem caused by your gps device, then its not my skin, and would be very suprised if it was roadrunner to be honest, are you running some sort of com port splitter maybe thats not behaving itself right ?
    CdR
  5. #155
    Mar 2005
    Sweden/Vaxjo
    Hi m8!
    Can't say much more then the fact that I love this skin... I've been using almost only freedom since it came and I'm still loving it.. and this is looking to be my next favorite!
    One small question though, I can't get it to load IG 2.1.2... Downloaded the new version this morning but when I press the GPS button it swtiches to the gps skin but it doesn't load IG or embed it anyway...
    if I switch over to freedom again it embeds just fine!
    Gonna take a 1000km trip this weekend so I thought I should try it out before going out with a mess to the swedish community about it...
    (any news on Freedrive 2 btw... )
    Swedish site for CarPC's
    http://www.bilpc.info
  6. #156
    Feb 2004
    Manchester
    you may need to remove the c01 line or C line from the external_gps.skin file if your using ig native.. let me know if that works
  7. #157
    Jan 2003
    CdR
    Well the easy way to test is to simulate the GPS getting no data in to FD and to see what happerns.
    If it helps the compass 'twitches' while waiting for data... its during this period the skin is 'stuck' both in control and display ( ie track times etc ) but not hung as you can press buttons and get audio feed back...ie the 'Vrooom / woosh'
    Terran
    PS Planning on using GPSgate soon - may be that will fix it.
  8. #158
    Jan 2007
    CdR,
    First off, as always, amazing work. I did seem to fnid something that I didnt see mentioned, so I thought I would bring it up. If you add 10 songs to a temp playlist, then you are listening to those songs, when you press and hold a song to delete, it will keep playing it, if you move forward or backwards a track to where that song is. It wont show in the list, but that song will play.
    Hope that makes sence.
    Cheers,
    RS
    __________________________________
    The NEW Design : 90%
    The NEW Install : 2%
    The Aspirin : Alot!
  9. #159
    Feb 2004
    Manchester
    Hi m8, yeah it makes sense, but I think this is a rr bug rather then a skin bug m8, can you stick a post up in the rr forum about this please :-)
    CdR
  10. #160
    Feb 2004
    Manchester
    Terran
    Can you let me know what your on about.. first you said the Sat indicator, which I took to be the thing at the top near the phone indicators.. then you have mentioned the compass now ? I havent got FD installed on this machine as it wont let me run SDK5.. It mght be that FD is ouputing a strange variable until its got a lock which is causing the lock up in the skin.. can you turn the debug on inside roadrunner and then have a look for me m8.. then I can stick something in the code to stop it doing it..
    cheers
    CdR
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
