Page 29 of 92 FirstFirst ... 19202122232425262728293031323334353637383979 ... LastLast
Results 281 to 290 of 919
Thread: Freedom Ultimate (Worklog)
  1. #281
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    Quote Originally Posted by CdRsKuLL View Post
    Hi m8.. you will need to add PLAYLISTPATH= in rr.ini file.. you will be able to set up this path in the settings skin in the end, I still need to do the paths bit yet
    so stick something like
    Playlistpath=C:\Documents and Settings\CdRsKuLL\My Documents\My Playlists\
    in rr.ini then this is where it will save your playlists to..
    to load them.. load the browser up.. click on FILE MODE .. then click on LOAD, it will then change the list on the left to your playlist folder..
    CdR
    Did it... No joy.. I'll try again in a couple of hours. Thanks.
  2. #282
    Jan 2007
    Hey CDR,
    I've got a auestion / suggestion
    For intergration of NCK could u intergrate a skin like this http://www.mp3car.com/vbulletin/road...sk-workes.html
    Think that would help a lot of the european customers.
    Thanx in advance
    PS on other id ... a traffic button that open's a internet traffic info page...
  3. #283
    Nov 2004
    St Louis
    Quote Originally Posted by pyros View Post
    Just an update on the XM, CdR. My computer isn't back in the car but everything else is still there.
    I had a play with the XM today. Found a lot of little nits, nothing major I hope:
    1. Lots of people use the wrong labels. Recheck the labels for STATION, XMSAT, XMTER, and GENRE. Your skin isn't pulling the label data just shows the label name (hint: change the label from text to variable). Also need a label next to Genre for XMFAV (I use several favorites lists and this label reminds me which one is loaded).
    2. I've attached a small png for you to include in your icons directory for the XM button icon.
    3. XM station (albumart) doesn't show up (could be same issue as 1 above). This would also be a great spot for a button to open XM Favorites Menu.
    4. Need to add some additional buttons: XMFAV, SCAN, SEARCH, RELOAD, CHAN+, CHAN-, FAV+, FAV-
    5. For some reason the playlist and actual playing station don't match. I don't know how to explain it, except to say the playlist shows channels 192-198 but the playing channel is 67. When I use th up/down arrows the playlist will shift briefly in that direction, but always jumps back to the original station. If I double click on another station it changes briefly but it jumps back to the original.
    Other than that, it works great.
  4. #284
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    While we are talking buttons CDR..... got stuck on the M6 last night and was playing with the web skin.
    Where you have lower buttons change ( ie from web to volume etc ) is there any chance you can add the following ?
    1) Online / Offline Indicator ( I guess a simple ping will do )
    2) A dial up connect button
    3) A dial up disconnect button
    ( Some info on that here http://www.mp3car.com/vbulletin/soft...-required.html - The code shows you the command line needed for both. )
    Terran
  5. #285
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi m8, will have a look fella,the browser should auto connect.. but I will add a connect / disconnect icon on the top bar of the other skins.. tapping the icon will toggle the connection .. will that do ?
    CdR
  6. #286
    Jan 2003
    CdR
    Cheers - Its all to do with hibernation etc if you read the other thread. Its not a prob for you as you dont use BT for dial up.
    Terran
  7. #287
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Hey terran why you don't use the rasdial to reconnect after hibernation? and for disconnecting use the same exit button from the browser skin to run rasdial /d? (also you can put a timer to execute /d after leaving the browser skin).
    To tell you the true the skin is good how it is right now and more buttons will make it to complecate.
    I'm in favor of a online label and maybe clicking it can connect and disconnect the connection. just my .02 cents.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  8. #288
    Apr 2007
    France/Paris
    Great
    Very impressive skin. Can't wait for the finish
  9. #289
    Feb 2004
    Manchester
    will be uploading a new release soon, not done much on it to be honest except redone the radio and added browse by albumart. I have also fixed afew bugs.
    CdR
  10. #290
    Apr 2007
    France/Paris
    Will you include some psd files?
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 10:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 12:40 PM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
