Page 37 of 92 FirstFirst ... 27282930313233343536373839404142434445464787 ... LastLast
Results 361 to 370 of 919
Thread: Freedom Ultimate (Worklog)
  1. #361
    Newbie Mattlocked's Avatar
    Jan 2005
    Madrid/Spain
    Hi again!...
    This skin is great but maybe I'm a bit of a R-tard... or the OSK button when using an external GPS app (like destinator) is not implemented... in previous Freedom releases there was an OSK button to launch a keyboard to enter your destination address or any related data... (See Images).. I can't lauch the keyboard to enter addresses with this new release... Am I doing something wrong or the osk for navigation it's not fully implemented yet?...
    Besides this little nuissance the skin is great, and having the ability to select custom bacground and text colour kicks ***!!!.
    Thanks a lot for your work...
    Matt.
  2. #362
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi m8, will add this in a day or so for you. I would of thought it will be in the alpha 0.4 version :-)
    CdR
  3. #363
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by Mattlocked View Post
    Hi again!...
    Matt.
    A bit OT but what navi is that...?
    Swedish site for CarPC's
    http://www.bilpc.info
  4. #364
    Feb 2004
    Manchester
    Thats a hacked Destinator that comes with centrafuse.. hes just started the destinator.exe which is inside the centrafuse folder.. you then need to amend a file to you can get to the onscreen menu.. simple stuff, there was a big thread about it somewhere If I remember.
    CdR
  5. #365
    Variable Bitrate Philhop's Avatar
    Apr 2006
    CDR any chance of having a button to do this on the fly .. http://www.mp3car.com/vbulletin/road...ontrol-16.html
    Its built into roadrunner now all it needs its a Setvol button to turn on , I guess It depends on if many user would use.
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
  6. #366
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by CdRsKuLL View Post
    Yeah I just spotted this, complete idiots.. I have called them and it should be back up within the hour.. needless to say I will be looking for a new host this week.. dont use ukhosts there complete tossers :-)
    CdR
    CDR - I'm on 1&1 now as F2S where too naff... got no complaints
    And they do cron jobs for certain traffic apps
    Terran
  7. #367
    Feb 2004
    Manchester
    Quote Originally Posted by Philhop View Post
    Hi m8.. yeah can add it no probs.. where would this button be best on the main screen maybe ? I could add it to the clock button, maybe a press and hold thing.. I havent got time really to read all that thread but defo interesting in adding this.
    I have been playing with the look (top bit).. what do you all think, better or worse.. ?
  8. #368
    Apr 2006
    Button would be best on the main screen , mabey push and hold would be the best bet other than that above the minimize button , perhaps that will be a little small.
    You dont really need to read through the whole thread all you need to do is add the command and then you can configure in RR.ini I think this is just a guess with out reading the readme which is at home or out in the car
    I Like the look at the top bit I think its better!, Ill have to make my car into a logo is it just the same method of putting the logo file in the right spot.
    GPSVOL is an indicator. It will show when a GPS signal is present. You can toggle the mastermute button to normal volume (then you can use the Vol+ and Vol- buttons to adjust the volume manually), to mute or Att Volume which is calculated by gps speed.
    Here is the part from RR.ini for the auto speed volume.
    speedatt=true (When you want to use auto volume)
    speedattmute=true (Toggles manual mute auto)
    speedattunit=mph (set this for miles or kilometers)
    speedattgrad=40 ( ? Guino maid know)
    speedattvola=10 (The start volume level)
    speedattvolb=25 (The max volume level)
    speedattspeeda=0 (When to start auto volume, at 0 Mph)
    speedattspeedb=75 (When to stop auto volume, at 75 Mph)
    speedattmode=line (Linear I think)
    speedattvolzero=70 (? Guin maid know)
    speedattvolgainat50mph=5 (Raises the volume 5% at 50Mph)
    speedattmaxstep=10 (Increments between min and max volume)
    You can set the volume at 0Mph and the max volume by any top speed you set.
    Hope that helps.
    You will need the newest version of RR
    Taken from the thread I think this is all thats needed
    my TURBO! Altezza!
  9. #369
    Apr 2006
    CDR a little off the topic but Freedom got featured in the NZPC magazine Link to my car mag Spread, Scroll down a bit. I think you will be pretty proud of this
    my TURBO! Altezza!
  10. #370
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    CDR, can you add support in this skin to make my car fly? Ideally, I would press a button under "Tools" called "Fly Fatass Fly" and my car would pause the music, announce "Flight Plan Engaged" (in a sexy female voice), and once my car has reached an altitude of 5,000 feet, the music would unpause (for safety reasons, of course). Let me know if you could implement this... I can help you with the code if you need it. This would only work on cars/trucks manufactured after 1978 though.
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
