Page 38 of 92 FirstFirst ... 28293031323334353637383940414243444546474888 ... LastLast
Results 371 to 380 of 919
Thread: Freedom Ultimate (Worklog)
  1. #371
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Nola111 View Post
    CDR, can you add support in this skin to make my car fly? Ideally, I would press a button under "Tools" called "Fly Fatass Fly" and my car would pause the music, announce "Flight Plan Engaged" (in a sexy female voice), and once my car has reached an altitude of 5,000 feet, the music would unpause (for safety reasons, of course). Let me know if you could implement this... I can help you with the code if you need it. This would only work on cars/trucks manufactured after 1978 though.
    I think RR already has a command for this. I know it works for my lambo. What happens is it activates the doors to open (now actiing as wings) and when I reach a certain speed (approximately 120mph) the rear end extends its tail rudders and up I go. The radio resumes after 2000 feet though. 5000 is pretty high up there. The only problem I have with it is once my doors are being used as wings, I have no enlosure so reaching mach speeds is pretty difficult.
    But of course installing a widget to control an external wing installation would be no problem. or maybe some collapsable fold down soft doors.
    IF you have any other ideas let me know. My project is nearly complete accept for the ability to reach mach speeds. Currently I am able to reach 270 mph in the air. I have too much wind resistance to allow me to safely reach higher speeds.
    New Age Garmin - Skin for RR
  2. #372
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by ThunderStick View Post
    Holy sh** your music unpauses at 2000 FEET????
  3. #373
    Variable Bitrate Philhop's Avatar
    Apr 2006
    Keep on topic!
    my TURBO! Altezza!
    ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
  4. #374
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    ok, I know something arnt lined up.. but because of the way I have designed the skin its not to hard to alter the top and bottom off every skin..
    CdR
  5. #375
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Nice! what about the buttons just like that but not flat, for the night skin?
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  6. #376
    Jan 2007
    New Orleans, LA
    Man, CDR, this thing looks super nice. Can't wait for you to release it!
  7. #377
    Newbie Lumenos's Avatar
    Aug 2006
    Germany
    Yeah, me 2 ... its getting more and more perfect
    @CDR
    Will the OSK Button be always implemented or just for Mattlocked ?
  8. #378
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Quote Originally Posted by Naesstrom View Post
    try and set the IG comport below 10... It seems to have some problems with 2 digit comports...
    I will try that thanks, as editing the registry just made it switch it back after I had loaded it once... I was using port 11 though so we will see!
    I am having a small issue with Freephone, phone is a Nokia 6133 that I believe runs the Symbian 40 series OS (Don't quote me on that!)
    Anyhow the phone memory numbers come up, but not the one's on the SIM card. After looking at the Debug I noticed it is pulling all the numbers, and also they do load into freephone, but don't show up in the list window. You can click on them though and it will list it in the box over the keypad.
    So not sure, pretty much it is like the numbers it is loading from the SIM come up black and then can't be seen. All the other tabs (phone, dialed, Rec'd) display perfectly fine though.
    Debug is attached if it helps
    Attached Files Attached Files
  9. #379
    Newbie Mattlocked's Avatar
    Jan 2005
    Madrid/Spain
    Thanks a lot man. Incredible support, and your skin Rocks!!. It's just in the proccess of becoming perfect.
    Incredible support. Expect some donations with this level of engagement with the community.
    Matt.
  10. #380
    Nov 2004
    If you like to donate a couple of pecetas please see this thread
    http://www.mp3car.com/vbulletin/road...reen-fund.html
    Thanks.
    Thanatos.
    Nissan Aux-in MOD
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
