CDR - Another bugette.... I've got a MP3 file with a very long TAG... I've noticed the text goes over the menu button ( ie Audio ) on the main screen rather than behind.
Terran
Printable View
Terran
Hey terran, the way to add favorites (the same for home and email actually) is to be at the current page and click and hold the link button after you see a splash that say "add" (for delete go to links and do the same)...I undestand what you saying cus those F- F+ buttons don't do nothing so far (and to tell you the true i like the cilck and hold future better)
Thanatos.
Ohh **** you right about the font size, I was paying more attention to see if it got added :p
Thanatos.
This web browser is finished apart from I want to pull the new button sense all away across the url at the top.. holding the link button does add the page into the links. :-)
Been busy adding stuff, its taking ages to be honest, lots of time being spent on the flash code at the moment. I've come across a few problems with the set path code Ive done in the settings menu, so I will be going with plan B..
CdR
.. Plan B works great. You can now select the paths from within RR :-) I have also added a create folder button as well, that jobs done for now. I also want to add the ability to browse for files, this will allow you to set gps software etc. I am trying to make it that every single thing in the rr.ini file can be configured through rr :-)
CdR
Hows my kitchen sink option coming on CDR :)
Not sure if this is any use for the Web Plugin.... some good sites like the MCE UK Portal one can be used using the following info.....
( Its all about using MS MCE Spotlight which is actually an advanced web page with checking in parts )
TerranQuote:
http://www.microsoft.com/onspot/default.aspx?view=en-gb ( Content set by contry code etc - detects MCE first if not goes to normal MCE home page )
http://myuk.aceinternet.co.uk/mce/default.htm
http://beta.narrowstep.tv/MCE/Player...175&chanid=359
http://news.bbc.co.uk/mediacenter/no.../bbcsplash.stm & http://news.bbc.co.uk/mediacenter/no...p/bbcindex.stm
Some MSDN stuff...
http://msdn.microsoft.com/library/de...plications.asp
http://www.microsoft.com/downloads/d...DisplayLang=en
http://msdn.microsoft.com/library/de...platepages.asp
I'm loving the new skin so far, it works brilliantly on my Sp13000, one thing has been bugging me a little though.
If I want to add all of my music in one go, how do I do it with this skin? with MC2.0 I'd just go to the load playlist screen and then press the 'add to' button and it'd add all the music in the list.
Now with the freedom ultimate skin I have to click each artist individually to add them. Is there something I'm doing wrong?
You should just be able to press and hold the top folder and everything under it will load. So for me all my music is in a folder called Mp3's and artist and albums are inside, if I wanted to load it all I would just click and hold the Mp3's folder and it would add all the music into a playlist.
Ah right, so I'd have to have my folder path 1 folder back from where it currently is then. It's set up as c:\music\artist\album at the moment with the audio path set as c:\music.
If I set the path to just C:\ I'd be able to do it that way.
