Page 42 of 92 FirstFirst ... 323334353637383940414243444546474849505152 ... LastLast
Results 411 to 420 of 919
Thread: Freedom Ultimate (Worklog)
  1. #411
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    CDR - Another bugette.... I've got a MP3 file with a very long TAG... I've noticed the text goes over the menu button ( ie Audio ) on the main screen rather than behind.
    Terran
  2. #412
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Hey terran, the way to add favorites (the same for home and email actually) is to be at the current page and click and hold the link button after you see a splash that say "add" (for delete go to links and do the same)...I undestand what you saying cus those F- F+ buttons don't do nothing so far (and to tell you the true i like the cilck and hold future better)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  3. #413
    Jan 2003
    Quote Originally Posted by thanatos106 View Post
    Thanatos.
    The F- F+ buttons change the font size ( I think ).... I did try and hold the link button too and that did nothing so I wonder if thats in the new Alpha.
    That been said I would have thought it easier to do that with the URL at the top of the screen ?
    Terran
  4. #414
    Nov 2004
    Ohh **** you right about the font size, I was paying more attention to see if it got added
    Thanatos.
    Nissan Aux-in MOD
  5. #415
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    This web browser is finished apart from I want to pull the new button sense all away across the url at the top.. holding the link button does add the page into the links. :-)
    Been busy adding stuff, its taking ages to be honest, lots of time being spent on the flash code at the moment. I've come across a few problems with the set path code Ive done in the settings menu, so I will be going with plan B..
    CdR
  6. #416
    Feb 2004
    Manchester
    .. Plan B works great. You can now select the paths from within RR :-) I have also added a create folder button as well, that jobs done for now. I also want to add the ability to browse for files, this will allow you to set gps software etc. I am trying to make it that every single thing in the rr.ini file can be configured through rr :-)
    CdR
  7. #417
    Jan 2003
    Hows my kitchen sink option coming on CDR
    Not sure if this is any use for the Web Plugin.... some good sites like the MCE UK Portal one can be used using the following info.....
    ( Its all about using MS MCE Spotlight which is actually an advanced web page with checking in parts )
    Terran
  8. #418
    Newbie Doogle's Avatar
    Jun 2006
    Sherwood Forest
    I'm loving the new skin so far, it works brilliantly on my Sp13000, one thing has been bugging me a little though.
    If I want to add all of my music in one go, how do I do it with this skin? with MC2.0 I'd just go to the load playlist screen and then press the 'add to' button and it'd add all the music in the list.
    Now with the freedom ultimate skin I have to click each artist individually to add them. Is there something I'm doing wrong?
    Getting back into the game...
  9. #419
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    You should just be able to press and hold the top folder and everything under it will load. So for me all my music is in a folder called Mp3's and artist and albums are inside, if I wanted to load it all I would just click and hold the Mp3's folder and it would add all the music into a playlist.
  10. #420
    Jun 2006
    Sherwood Forest
    Ah right, so I'd have to have my folder path 1 folder back from where it currently is then. It's set up as c:\music\artist\album at the moment with the audio path set as c:\music.
    If I set the path to just C:\ I'd be able to do it that way.
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
