Page 50 of 92 FirstFirst ... 404142434445464748495051525354555657585960 ... LastLast
Results 491 to 500 of 919
Thread: Freedom Ultimate (Worklog)
  1. #491
    Newbie carlospelos's Avatar
    Dec 2005
    Spain
    Quote Originally Posted by CdRsKuLL View Post
    Is the slow down just on the audio player screen when swapping tracks ? Everything else should be the same really. The reason its slowed down is because of the extra code thats needed to parse each line. I will try and improve on this but I'm unsure if its possible.
    CdR
    Hi, Thanks for this great job.
    My CPU is about 40-50% with FU playing music. If I minimize RR, it goes down till 15%. I only notice this with FU.
  2. #492
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by volke View Post
    can someone help me whit my clock..1 hour difference ????
    volke
    denmark
    The clock at the top left is set by RR, the flash clock in the middle is set inside the flash code.
    CdR
  3. #493
    Newbie dj_thomasD's Avatar
    Feb 2005
    athens-greece
    anyone have notice that at 0.4 for some reason skin options dosent apply the commands anymore...... or its just me,
    nothing have changed on my pc conf
    Also rhe skill stalls when you re going to config screen i mean i can navigate on it but i cant return in my main screen and after that everything freezes
    rolled back to 0.3 and everything worked flawless
    carpc Status
    hardware: 100%
    GPS:100%
    Phone:100%
    RR frontend=100%
    LiveTV=100%
    Radio = 100%
    Moving Instalation from Old car to new one
  4. #494
    Oct 2006
    denmark
    cdr can i set the flash clock.....
  5. #495
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by dj_thomasD View Post
    Every thing here worked fine, the skin changed colors and went back to the main screen. It did restart RR on each change tho'
  6. #496
    Feb 2005
    athens-greece
    Quote Originally Posted by treetop777 View Post
    maybe it is something wrong with my config then i will retry with a fresh rr install and skin and il be back 2 u
    carpc Status
    hardware: 100%
    GPS:100%
    Phone:100%
    RR frontend=100%
    LiveTV=100%
    Radio = 100%
  7. #497
    Sep 2006
    War-Town, GA.
    GPS Full Screen
    I can't get IG3 to go full screen, i hit the logo on the upper right and nothing happens. I done some probing and testing but can't figure it out.
    I compared Ultimate's external_gps and gps_full skin files to Freedom's and they look identical. I also opened Ultimate in RRSkinEditor to see what command is under the logo but the skin don't show up - it's like invisible ??
    gpsfull.swf is there; ignative is set to "true" and the A01 line is commented out.
    I'm testing the latest release 0.4
    Can somebody point me in the right direction..
  8. #498
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    So you saying that you delete the A01 line?? if so you deleting the grong one!! you meant C01 which is the clip region.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  9. #499
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by thanatos106 View Post
    Thanatos.
    You're absolutely right, i meant C01 (in the external_gps.skin); i put /, in front of it which is supposed to resolve a conflict with ignative=true. A01 is intact.
  10. #500
    Jan 2007
    For some reason, i noticed my visual isnt working at all. The box opens up, but its blank. I check in my rrconfig, and its set to avs. I also tried the others (milkdrop) and setting the custom and using the name of the window that winamp uses for visuals. I bumped back to the last version and it works... Anyone else have this?
    __________________________________
    The NEW Design : 90%
    The NEW Install : 2%
    The Aspirin : Alot!
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
