Nice... I never even bothered to check that... That solves that. :) Thanks!
Printable View
I tried to register flash.ocx but windows pop up me "Library load ("flash.ocx") failed...."
Then I get the flash.ocx from windows\system32\macromed\flash and put it in system32 then run the cmd and register this flash.ocx file
the result is:after starting road runner emediately freez and only end process is the oportunity :yield:
please help me what to do...?
I'll try to unregister this ocx but the problem is stil why windows pop up the thing above?
Look at post #4 here http://www.mp3car.com/vbulletin/rr-f...-too-fast.html and see if it help.
:focus:
Ok il give up dunno what else to do
I have used the 0.3 beta since today on my lilliput Epia M-1000 with 512 mb ram flahless I mean it was not the faster in the world ( 1 sec maybe 1.5 responce) but it did work ....At the new updat ei cant use the skin anymore dunno why...it i can only access the configuration screen and even on this one i dosent commit the changes i made.......any other buttons fail to responce :( ....... the bad think is that on my desktop pc with the same configuration of RR skin works really fast and its beutyfull (but its a amd XP 3.2)....So my best guess is that the skin code have become to heavy for epia mobos........ i cant figure out how a skin like Freedom 2.1 with is flash 8 based (and flah 8 its really HEAVY) run smooth and even alpha 0.3 works and the new one is not.....anyway if anyone have figured a way to solve the problem maybe il be back on it but until then ....i have to lose the nest skin ever
Most of this skin works great on my 1.33ghz p3. The problem I have is that video will not play full screen without slowing to a crawl. It seems to slow down after the controls autohide after 4 seconds. I have tried disabling this in rrconfig, but then it doesn't go full screen. I have tried using xvid and ffdshow codecs with the same result. Any suggestions?
From RR readme.txt:
videoautohide=true|false
This tells if the video controls should hide automatically.
If false, the controls hide when clicking on the video window.
So you can still hide the controls.
Search for a codec pack called "CCCP", it fixed some choppy/slow video problem i had. Good luck.
CdRsKuLL, I believe you mentioned a while back about adding an option to change or turn off the sound events when a button is clicked. Would you keep this in mind down the road when you get FU close to completion? Thanks. BTW this skin is the best in my book.
CDR - I see the web browser autoconnects now but It some times has if you have it started ( The web app ) and then move to another screem and hibernate but dont have your phone one you. Sort of hang around for ages once you restart.
Any chance you can add a manual option too as discussed above ?
I've also noted the 0.4 seems slower loading it too in general.....
Cheers
Terran
Another small question about the buttons... really nice that u've added the option to have more menus at the start screen... can someone explain what code I need to use to load a external .exe in the skin... I tried modding the ones for freephone but didn't get it to start the file!
