Page 57 of 92 FirstFirst ... 7474849505152535455565758596061626364656667 ... LastLast
Results 561 to 570 of 919
Thread: Freedom Ultimate (Worklog)
  1. #561
    Nov 2006
    14 Pin Compaq Power Supply
    Quote Originally Posted by winnox View Post
    Also, the compaq psu has a 14 pin connector, is there a place that sells convertor cables to go from 20 pin atx to 14 pin, or am i looking at a nice soldering job ?
    Off topic but here is a link that should help:
    http://www.mp3car.com/vbulletin/powe...er-supply.html
    Commell LV-671M 2.0ghz Intel Dothan 512MB SDRam
    Xenarc 800TSV Touch Screen, MiniPCI Intel® PRO/Wireless 2200BG w/External Antenna
    GlobalSat BT338 GPS, Linksys USB Bluetooth Adapter, Opus 250 PS
    Road Runner, Freedom Ultimate, iGuidance 3.0
  2. #562
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by akberpaf View Post
    Hi,
    Can someone please help me i am haveing several issues the Ultimate Skin.
    1. Sound: I cannot control it properly as soon as I hit "-" it drops the sound to zero.
    2. I am unable to apply the color change. When hit save in the screen where there is the color grid nothing happens. I relaunched it several times but nothing happened. (someone sugested to update my flash player and I did the only thing that accomplished was that now i can select the color. But that change does not get applied to the rest of the skin.)
    3. Is there a way to hide the top bar in GPS screen. I am using Iguidance and the top portion of the status bar covers alot of map.
    If someone can please help me I would be really greatful.
    The "full screen" GPS isn't working yet, it should work by hitting the logo while in the GPS screen but nothing happens. It should be easy to implement later; just have to make the button (the logo) call/trigger the skin.
    About you colors; if you didn't upgrade flash with Internet explorer then it didn't install right. Upgrade with IE only.
  3. #563
    May 2005
    Quote Originally Posted by treetop777 View Post
    The "full screen" GPS isn't working yet, it should work by hitting the logo while in the GPS screen but nothing happens. It should be easy to implement later; just have to make the button (the label) call/trigger the skin.
    Thanks for the reply. I finally got the color things to work ok.
    Any advise about the volume issue?
    Thanks.
  4. #564
    Sep 2006
    War-Town, GA.
    Set Ultimate's volume to zero then go into windows and set your master volume control also to zero. From then on, adjust the volume from within Ultimate and leave the windows volume control alone.
    Hope it fixes your problem.
  5. #565
    Low Bitrate bungee91's Avatar
    Aug 2006
    South of Chicago, IL
    Quote Originally Posted by Naesstrom View Post
    Just a quick question...
    I'm running this with freephone and it's working great as usual... the only thing is that I need to go to the phone screen once for it to connect...
    I remember when using Freedom skin there was some setting that it should connect to the phone every time it started the skin...
    anyone remember the line for that?
    Off hand no, but I do remember the option in one of the files...
    I would also like to have this option added back in, so bump for that.
    Also and I haven't looked so it may be an option to turn off, but is there a way to disable the beeping noise when you get a call or atleast have it at a set % from the volume you are currently at?.. If I have a song turned up and that thing starts ringing it practically leaves me deaf
  6. #566
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Thanks.
    Check in RRConfig that your only mapped to the master volume, not all.
    1. open rrconfig.exe
    2. click the music tab
    3. map sound for weaker sound cards - set to master
    let me know if this solves your problems
    Will get back to it soon, just got afew family things to sort out first
    CdR
  7. #567
    Nov 2005
    welcome back
  8. #568
    Mar 2006
    I have some question.
    Why I used this skin very slowly. The skin expend a lot of CPU resource, about exceed 80%, My computer is M10000, C3 1.0G 512M.
    Cpu used about less than 40% when using another skin
    I very like this skin, wish better and better
  9. #569
    The released version is 0.3 or 0.4?
    0.3..I got, but 0.4, which is link on 1st thread, is dead link. If there s 0.4, where to get it? Thx
    BeuZ
  10. #570
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    Hey, CdR, Welcome back.
    This thread took off and it's been a while since you made any progress reports on this. One thing; I was wondering if you, or anyone in this forum could create a skin for the milage plugin. It is a nice feature to have to calc all the miles you drive and get a cost-per-mile total and the average speed on a trip. Is this possible?
    Thanks.
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
