Page 58 of 92 FirstFirst ... 8484950515253545556575859606162636465666768 ... LastLast
Results 571 to 580 of 919
Thread: Freedom Ultimate (Worklog)
  1. #571
    lambosprit's Avatar
    Sep 2006
    UK
    I've got the millage plugin working with this skin but I just used a cut down version of the skin supplied with it so it doesn't look right. I could send if you were still interested. On doing this though I've found that the new version of RR doesn't seem to allow units in imperial any more, only metric. Tried the internationalization both on and off. I'm sure it isn't this skin because the indicators all come from rr. Anyway its yours if you want it.
  2. #572
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Any one got the EQ to use the presets / save the presets ? I have a few I want to use but I just dont seem to get them to work even though the EQ does.
    Terran
  3. #573
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    If you set the eq to what you want and press and hold the preset button (should hear a sound confirming its saved) it will create the preset, I think it saves them as freedom named presets in the roadrunner folder, just create 1 then you will know what its called and just call yours the same and overwrite it.. give me a shout on msn if your still having probs
    CdR
  4. #574
    Feb 2004
    Manchester
    Quote Originally Posted by lambosprit View Post
    Hi m8, if you want me to include this in the next release then let me have what you have done and I will stick it in the zip
    cheers
    CdR
  5. #575
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by CdRsKuLL View Post
    cheers
    CdR
    here you go. Tried to match the skins as well but not in flash I'm afraid.
    The tripmeter skin is what you link too from the main menu. (for me &mainbut9=TripMeter@icons\video.png@LOAD;tripmeter .skin&)
    The rest are called from that skin.
    Attached Files Attached Files
  6. #576
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by bungee91 View Post
    Off hand no, but I do remember the option in one of the files...
    I would also like to have this option added back in, so bump for that.
    Also and I haven't looked so it may be an option to turn off, but is there a way to disable the beeping noise when you get a call or atleast have it at a set % from the volume you are currently at?.. If I have a song turned up and that thing starts ringing it practically leaves me deaf
    Agree to a 100% at the last part... it's a bit high sometimes after driving for a while and the music's getting higher and higher...
    I have another strange thing with freephone btw, I've connected it with a USB cable and using a BT handsfree... if I answer the call using the buttons on the skin the sound is getting transfered to the phone but if I answer using the button on the handsfree I get the sound there.. anyone else having the same problem... (a bit OT I know...)
    cheers
    CdR
    Great... I love the milage plugin, just wish it had some more functions like having options to enter oilchange milages and so on... besides that it's one of the best milage plugins so a matching skin for FU would be sweet!
    Swedish site for CarPC's
    http://www.bilpc.info
  7. #577
    May 2005
    Hi Can someone please tell me why the speed does not work in my RR. the clock on the main menu works fine but when i change to speedometer it does not work. I am using Iguidance 3.0 and the speed works there ok.
    Please let me know if I can do to make it work.
    Another issue I am having is the lag after I hit any button. It seem to take a while for some actions to happen. It is ok sometimes but other times is super slow.
    Any suggestions...
    Thanks in advance...
  8. #578
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    Quote Originally Posted by akberpaf View Post
    Did you sply the ports for the GPS?
    If you use 1 port for GPS without splitting, its probably already in use by Iguidance.
  9. #579
    May 2005
    Quote Originally Posted by peijffertje View Post
    Hi thanks for the reply ... but how do you split the port? and where do you set the port for GPS in RR?
    thanks.
  10. #580
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    thanks.
    Search for Xport
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
