Page 59 of 92 FirstFirst ... 9495051525354555657585960616263646566676869 ... LastLast
Results 581 to 590 of 919
Thread: Freedom Ultimate (Worklog)
  1. #581
    May 2005
    Quote Originally Posted by rando View Post
    Search for Xport
    Hi,
    Thanks i tried to search for it but did not really find any thing useful. it shows up on several posts but no where to downlad it from or how to use it for my problem. can you please elaborate on where to get this program and how to use it for my situation.
    Thanks again.
  2. #582
    Low Bitrate mrcanngo's Avatar
    Jun 2006
    Vancouver
    Quote Originally Posted by akberpaf View Post
    Hi,
    Thanks again.
    i think he meant to google it. Here is the link:
    http://curioustech.home.insightbb.com/xport.html
    basically you load it up. Determine first what port your actual GPS is on.
    Within the Xport program, you pick that source port and than you click on "virtual ports" at the bottom section.
    Once you click "enable ports" these new virtual ports will be created. For mine, my GPS is on port 3 and i created virtual port 7 and 8.
    From within the road runner config to enable the compass i said that my GPS was on port 7 and from within iguidance (or your GPS program of choice) i slected my gps to be on port 8.
    Hope that helps.
    BTW- Great skin CDRskull!
  3. #583
    May 2006
    Quote Originally Posted by mrcanngo View Post
    Hope that helps.
    You can also use this software http://franson.com/gpsgate/
  4. #584
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by CdRsKuLL View Post
    If you set the eq to what you want and press and hold the preset button (should hear a sound confirming its saved) it will create the preset, I think it saves them as freedom named presets in the roadrunner folder, just create 1 then you will know what its called and just call yours the same and overwrite it.. give me a shout on msn if your still having probs
    CdR
    Well thats what I thought... and I remember the convo. I get the message that its saved & the beep but in reality it does not seem to.
    Ideally too I'd like to give custom names to the buttons as well like you had in MC2 eg Reset, Pop, Classic etc etc.
    Have you tried the presets your self and tested saving ? The problem seems to have stayed with all the iterations so far... I just assumed you would get to it eventually.
    Terran
  5. #585
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Cdr, will you plz plz plz compile a version with the greek regional settings, so i can fianally use your skin
    it hurts not being able to check it out
  6. #586
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    That would be great. I've been wating to get this plugin working since it came out. It's very useful for those of us who want to keep track of the fuel compsumption in the vehicle! I believe they also included Vehicle maintenance cost and tracking.
  7. #587
    May 2005
    Hope that helps.
    Hi thanks alot man that fixed it....
  8. #588
    May 2005
    Quote Originally Posted by treetop777 View Post
    Set Ultimate's volume to zero then go into windows and set your master volume control also to zero. From then on, adjust the volume from within Ultimate and leave the windows volume control alone.
    Hope it fixes your problem.
    Thanks alot man that fixed it...
  9. #589
    Low Bitrate shuggyboy's Avatar
    Jan 2006
    codecs?
    Iknow this has probably been brought up a thousand times, but what codecs do you guys use?
    I am having a lot of problems with the video on my system, and I think it may be down to the codecs being used...
    Celeron 2ghz, 1 gig ram, 200 gig sata, DRU-R100 radio, wifi g, 7"lilliput touchscreen, opus 150w dc-dc, laptop slot load Dvd, BU-353 GPS , Destinator, Road Runner MC2.0
    http://www.mp3car.com/vbulletin/show...ord+focus+2000
  10. #590
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I'm using the CCCP codec Pack and haven't had any vid problems since,try it.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
