Page 63 of 92 FirstFirst ... 13535455565758596061626364656667686970717273 ... LastLast
Results 621 to 630 of 919
Thread: Freedom Ultimate (Worklog)
  1. #621
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi m8 list the bugs and I will see what I can do, I dont want to release the psd's yet for it as its not finished and I may have a buyer.
    CdR
  2. #622
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    Eh - A Buyer ??? Good on ya.... just make sure you add the new Silabs Plugin
    Bugs - on 0.4 it slows down to a point where Flash says the script will cause problems.. and infact it does the PC crashes by the looks of it.... I posted a while back.
    Also instead of the auto dial on the web browser you need a manual disconnect / connect button so that BT connections can be restarted....
    Terran
  3. #623
    Dec 2006
    Hi m8.. yeah we rocked at the quizz ;-p
    you can set which lines you want to configure by simply opening the menu.txt file, the top line will look like something like 1,2,3,4,5 .. these represent the number of the mixer line...
    the status screen isnt finished.. BUT if your on about the settings screen just click the TIME on any screen. Still havent decided on the best way to do the status screen, you can if you wish remove it from the menu by changing the menu.txt again :-)
    hope this helps
    CdR
    cheers mate will have a look at that when i get 5 mins......
  4. #624
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Speaking of bugs..
    The logo button to go to full screen GPS don't work..
  5. #625
    lambosprit's Avatar
    Sep 2006
    UK
    Bugs?
    Not sure if these are bugs or setup.
    The logo doesnt appear top right in version 0.4. If I go to the 0.3 top it works fine.
    My audio browser by file doesn't work .album art does. I've tried 0.3 and 0.4.
    The screen saver doesn't come on but I assume thats linked to my audio browser not working.
    Any one confirm these are working in 0.4 please?
  6. #626
    Sep 2006
    War-Town, GA.
    There's no logo at all? there should at least be the FredomUltimate logo. Check for a "logo" folder in the Ultimate folder. You can use any of the logos in that folder by changing the line &logo=logo\ford.png& in skin.ini or rr.ini (in my case i'm using the Ford logo)..
    Both Audio browsers works fine here.
  7. #627
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by lambosprit View Post
    I'm no expert but I'll try to help. sorry if the questions seem obvious.
    Have you tried running the app on its own. You should just be able to double click the exe and all will run ok. You should see the skins I attached when you run it this way as well.
    If that all runs fine then it must be something to do with the button code. I had the same thing because my path to the install was incorrect. I would suggest checking that the you actually have the traffics cams software installed in your road runner directory in a directory called traffics cams. If not you would have to change the line to point to the correct place. Other than this you could post your menu.txt file and I'll have a look.
    It all works fine by it's self and it works in the DigitalFX skin, the only place it doesn't work in is in the Freedom skin. So i'm thinking its the button code. I'm not sure if this is the problem but i have RR in c:\road runner and not C:\program files\road runner. I don't see that as beening the problem since the button code looks like it point the the directory. Also if i change "$rrpath$\Traffic Cams\" to 'c:\road runner\traffic cams" it doesnt make a difference.
    Thanks,
    Tim
  8. #628
    Aug 2003
    Federal Way, WA
    I believe I'm using .4 and I have the logo and album art works fine. I have not seen any screen saver. Didn't even know there was one, but I've not used any version except .4.
    I did screw something up though because I no longer have album art on the audio player.
  9. #629
    Jan 2003
    CDR - Just wondered if you'd had a chance to lok at this skin yet like we chatted about ?
    Also heres the link for the Silabs plugin too which would be well deserving of a skin....
    siLABS RADIO PLUGIN
    Terran
  10. #630
    Feb 2004
    Manchester
    Hi m8, not had a chance as yet but I will try to do it tomorrow, but I need to make some pennys first on ebay :-)
    CdR
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
