Page 67 of 92 FirstFirst ... 17575859606162636465666768697071727374757677 ... LastLast
Results 661 to 670 of 919
Thread: Freedom Ultimate (Worklog)
  1. #661
    Newbie Niob's Avatar
    May 2007
    Norway
    You can't. As he has removed the links. Only the first release is awailable.
    You kan se it here http://www.freedrive.co.uk/forums/lo...ks.php?catid=5
    I think he has a buyer of it or something. (erlier post in this thread).
    Greate skin. Hate to loose it.
    edit: hmm.. i might be rong. As i see the one i just linked to is named freedome end not fredome ultimate..
  2. #662
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Err NO,this skin is still available,you can get it from here = http://www.freedrive.co.uk.
    It's only Freedom 2.1 that was pulled and that was due to its Centrafuse looks.
    Rumor has it that a link to Freedom 2.1 still exists,depends who you talk to.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  3. #663
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Niob View Post
    http://www.mp3car.com/vbulletin/rr-s...orklog-42.html
    the direct link for downloading ultimate.
  4. #664
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just click on the link for 0.4 in my signature.. :-) will get back to it soon
    CdR
  5. #665
    Constant Bitrate C4DAO's Avatar
    Apr 2007
    Cardiff
    Good to know!
    I'm loving FU so far, but have come across a minor issue - my apologies if it has already been mentioned - The Album art display when choosing a playlist doesn't "update", and stays on the first (the "top") playlist. Any idea if this is a bug of FU, or something that I'm doing wrong?
  6. #666
    Dec 2005
    Tampa, FL
    First off... totally awesome skin
    I am trying to play CDs and DVDs. I am wondering if there is a config file I must change in order for the skin to know the drive location (d:\)?
    Thanks,
    Tony
    Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
    Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
    99% done... [never completely finished... a continuing hobby]
  7. #667
    Low Bitrate crispyrabbi's Avatar
    Nov 2006
    Sweden
    Since I started using this skin the hibernation has failed a couple of times. Not 100% certain that is is FU that is causing this. Maybe someone else has experienced similar events?
    AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
  8. #668
    Newbie jte69's Avatar
    Oct 2005
    Germany
    Hello
    The ultimate skin consist of three menus. How can I create a fourth menu, in order to include new softwares and to start the new softwares, plugins etc. as for example speed fan?
    How can I insert a logo on the top right, as for example AUDI logo?
    Can I also insert a flash/animated audi logo?
    Thank you for your support.
    Regards
    Fireball
    Itís not a trick itís an Audi
    My A6
    http://www.pictureupload.de/Mein_A6-gid2827.html
  9. #669
    Feb 2004
    Manchester
    hi m8, open up menu.txt in the skin folder and I think I added a line where you can change the number of menus it shows.. just change this to 4 and then you can add them.. let me know if its there as I cant remember.. lol
    the logo location is stored in the skin.ini ... think its just called logo.. , just point this at your new logo (check out the ones in the logo folder to get the right size.. )
    ta
  10. #670
    Oct 2005
    Germany
    Hello
    In your Alfa 0.3 skin the menu.txt contains the following text:
    &numberofmenus=3& in the menu.txt
    and I changed the &numberofmenus=3& to &numberofmenus=4& and It worked
    But in your Alfa 0.4 Skin this &numberofmenus=3& does not exist. I haved copied the &numberofmenus=3& into the menu.txt of the Alfa 0.4 and I have changed to &numberofmenus=4& but it doesnīt work
    In the Alfa 0.3 it works great
    Regards
    Fireball
    My A6
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 10:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 12:40 PM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
