Page 72 of 92 FirstFirst ... 22626364656667686970717273747576777879808182 ... LastLast
Results 711 to 720 of 919
Thread: Freedom Ultimate (Worklog)
  1. #711
    Constant Bitrate rsxtypes's Avatar
    Nov 2006
    Dallas, Tx
    Is there a way to disable the key touch tones? I haven't found it in the options menu. Is there some other way to do it?
  2. #712
    Feb 2004
    North Aurora, IL
    what happened to the slide bar that allowed us to scroll through large playlists?
    i could have sworn when i previously downloaded version .4 it was there but now its gone....
    maybe im goin senial
    I wish i knew how to do fiberglass work...
  3. #713
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by theheel View Post
    You see it?
    (Click that blank button under "132")
  4. #714
    Nov 2006
    Dallas, Tx
    @ treetop77
    Mine looks way different than yours. Whats up with that? I don't have a visuals button. The background behind my Song title is grey and my list doesn't look like that.
  5. #715
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by rsxtypes View Post
    @ treetop77
    You probably don't have the latest Alpha-0.4; i have one i downloaded 4/15 and another 4/19 (which is the one you see above).
    Just download the latest version..
  6. #716
    Feb 2004
    North Aurora, IL
    that looks like the alpha .4 i had before i reformatted my computer. It had the the scroll bar.. but it also had a lot laggier response time than the alpha .4 i have now after i reformatted.
  7. #717
    Nov 2006
    Dallas, Tx
    Nope I just redownloaded when I saw yours. He must have changed the file or linked to the wrong file.
    Edit: Confirmed. The one on his website is different from the one in his signature. The one in is signature is actually .3 or so says the readme file.
  8. #718
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    All based on 0.4
    • The browse by album art some times hangs the skin ( but not flash ) especially after a hibernation
    • I've got a MP3 file with a very long TAG... I've noticed the text goes over the menu button ( ie Audio ) on the main screen rather than behind - I've scince noticed this on the audio screen too.
    • Under the web browser if you use a very long url ( eg the project I showed you cdr ) you cant see what your typing as it goes off the screen once its reached the full length of the URL entry box rather than shuffle accross....
    • Where you have lower buttons change ( ie from web to volume etc ) is there any chance you can add the following on the web browser ?
      1) Online / Offline Indicator ( I guess a simple ping will do )
      2) A dial up connect button
      3) A dial up disconnect button
      4) An option for Auto or manual
      ( Some info on that here http://www.mp3car.com/vbulletin/soft...-required.html - The code shows you the command line needed for both. )
      I see the web browser autoconnects now but It some times has if you have it started ( The web app ) and then move to another screem and hibernate but dont have your phone one you. Sort of hang around for ages once you restart. May be if you can through in the option to run a command first too for those of us that use BT ?
    • Any one got the EQ to use the presets / save the presets ? I have a few I want to use but I just dont seem to get them to work even though the EQ does.
      ** More info - Tested just now. If you press and hold the preset it updates it but saves it so that if you press any of the other eq presets the same comes back - ie one setting for all the presets. Also had a hick up where after a while ( I was waiting ) it went to the main screen and turned the volume up full. When I when back it would not let me check the EQ manually let a lone by the presets.
      WORK AROUND - I got it working - But I know the issue. Yes you can set and save but if you dont exit out the screen and then go back in you cant use them / wont update the screen. To fix - do youor settings then go to the main screen THEN test them.
    • I did this under the Title section in rrconfig and I cant seem to get it to work... am I been dim ?
      "%title%***%genre%"
      It still shows undefined underneath... and I know all my MP3s are sorted as well this time.
      ** Update ** - Tags show ok in genral on 03 - is this an ID3 / ID1 tag its looking for ?
    • Skin support for Webmasters GPS Tracking app - http://www.mp3car.com/vbulletin/gps/...-tracking.html ( Gatso Huter & Traffic Cams Done Already )
    • Skin support for ICE radio plugin with more advanced features for the Silabs
    • On my 12000 runs a lot slower than 0.3 - a lot. Although I dont get the same scripting error message I posted a while back. Screens tend not to change and a reset is needed ( ie mixer to main ) or they take for ever.
    • Album Art image for Radio
    • Screen Saver while on Radio ( like the Audio section )
    CDR - Any upates ? Would any bribery work at this point ?
    Update 290707
    Well, I've been using all the options enabled for a week now. Bar the fact its a tad slower for obvious reasons its not failed on me yet.
    So - on that basis I'd say there is some coding some where that needs looking at for the cut down versions.
    Terran
  9. #719
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by ccsnet View Post
    Didn't know that it had support for GATSOHunter... need to check that out...
    Otherwise I agree with those two, maybe most the Silabs radio skin, I'm probably getting my stick this week by mail...
    Swedish site for CarPC's
    http://www.bilpc.info
  10. #720
    Aug 2006
    Great skin CDR!! I can't wait to see a finished product.
    I've noticed also what ccsnet has pointed out on the lag.
    I just loaded it up last night and I've noticed that some of the transitions and effects seem a bit laggy. I changed the settings to have a slow processor speed and that helped some.
    However, running a P4 Mobile processor, I don't think that it should be considered a slow processor.
    Also, when enterring the "Status" page, just a vertical bar shows up and I have to click the top of the bar where I can only see the left side of the clock in order to proceed to the settings page.
    Otherwise, I'm loving the skin so far and looking forward to the updates and, most of all, the finished product!
    Drop that iPhone skin and work on this one again!!
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
