Page 74 of 92 FirstFirst ... 24646566676869707172737475767778798081828384 ... LastLast
Results 731 to 740 of 919
Thread: Freedom Ultimate (Worklog)
  1. #731
    Jan 2007
    I had to reinstall my carpc after the machine fell outa my trunk as I was putting in a new vid card, and it slipped.
    I had .04 beta, and now I can not seem to find it any more. the version in cdrs sig is .03...
    Anyone have a link I can grab .04
    __________________________________
    The NEW Design : 90%
    The NEW Install : 2%
    The Aspirin : Alot!
  2. #732
    Aug 2006
    http://www.freedrive.co.uk
    The one on the front page should be .4 Alpha and should be up-to-date. At least, that's the one I thought was the most recent...
  3. #733
    May 2006
    Calgary, Alberta
    This skin is awesome except iGuidance won't embed. It just loads in a separate window on top of the skin.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  4. #734
    Aug 2006
    Quote Originally Posted by Maheriano
    You have to remove the line C01,0,35,800,480 in the "gpsfull.skin" file.
    Should work fine after that.
  5. #735
    May 2006
    Calgary, Alberta
    Quote Originally Posted by ctsoccer13 View Post
    Tried this and it didn't work. The only way it worked was if I first loaded it in another skin, then changed skins to FU then loaded the GPS screen in FU. I'm piping nowarning when loading the application, will that do anything?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  6. #736
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    do you have ignative=true in your rr.ini file. if so delete the c01, 0, etc and you should be ok
  7. #737
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Well, I've been using all the options enabled for a week now. Bar the fact its a tad slower for obvious reasons its not failed on me yet.
    So - on that basis I'd say there is some coding some where that needs looking at for the cut down versions.
    Terran
  8. #738
    Jan 2003
    All based on 0.4
    • See ** - The browse by album art some times hangs the skin ( but not flash ) especially after a hibernation.
    • I've got a MP3 file with a very long TAG... I've noticed the text goes over the menu button ( ie Audio ) on the main screen rather than behind - I've scince noticed this on the audio screen too.
    • Under the web browser if you use a very long url ( eg the project I showed you cdr ) you cant see what your typing as it goes off the screen once its reached the full length of the URL entry box rather than shuffle accross....
    • Where you have lower buttons change ( ie from web to volume etc ) is there any chance you can add the following on the web browser ?
      1) Online / Offline Indicator ( I guess a simple ping will do )
      2) A dial up connect button
      3) A dial up disconnect button
      4) An option for Auto or manual
      ( Some info on that here http://www.mp3car.com/vbulletin/soft...-required.html - The code shows you the command line needed for both. )
      I see the web browser autoconnects now but It some times has if you have it started ( The web app ) and then move to another screem and hibernate but dont have your phone one you. Sort of hang around for ages once you restart. May be if you can through in the option to run a command first too for those of us that use BT ?
    • See ** - Any one got the EQ to use the presets / save the presets ? I have a few I want to use but I just dont seem to get them to work even though the EQ does.
      More info - Tested just now. If you press and hold the preset it updates it but saves it so that if you press any of the other eq presets the same comes back - ie one setting for all the presets. Also had a hick up where after a while ( I was waiting ) it went to the main screen and turned the volume up full. When I when back it would not let me check the EQ manually let a lone by the presets.
      See ** - WORK AROUND - I got it working - But I know the issue. Yes you can set and save but if you dont exit out the screen and then go back in you cant use them / wont update the screen. To fix - do youor settings then go to the main screen THEN test them.
    • I did this under the Title section in rrconfig and I cant seem to get it to work... am I been dim ?
      "%title%***%genre%"
      It still shows undefined underneath... and I know all my MP3s are sorted as well this time.
      ** Update ** - Tags show ok in genral on 03 - is this an ID3 / ID1 tag its looking for ?
    • Skin support for Webmasters GPS Tracking app - http://www.mp3car.com/vbulletin/gps/...-tracking.html ( Gatso Huter & Traffic Cams Done Already )
    • Skin support for ICE radio plugin with more advanced features for the Silabs
    • See ** - On my 12000 runs a lot slower than 0.3 - a lot. Although I dont get the same scripting error message I posted a while back. Screens tend not to change and a reset is needed ( ie mixer to main ) or they take for ever.
    • Album Art image for Radio
    • Screen Saver while on Radio ( like the Audio section )
    CDR - Any upates ? Would any bribery work at this point ?
    Update 290707
    ** = Well, I've been using all the speed & transistion options enabled for a week now. Bar the fact its a tad slower for obvious reasons its not failed on me yet, even the EQ works as it should.
    Terran
  9. #739
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Maheriano View Post
    Sounds like you are still in the dark ages with IG.
    Make sure you have "ignative=true" in rr.ini;
    In RRConfig set the GPS path to iguidance(UMPC).exe;
    make sure window name is "iGuidance" and GPS Mode is "external"
    Should work without "piping" or any other IG helper apps..
  10. #740
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    Screen Sounds
    Has anyone figured out how to do away with the sounds when changing screens?
    Other than this CDR loving the skin
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 09:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 02:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 11:40 AM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 02:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 01:43 PM
