Page 75 of 92 FirstFirst ... 25656667686970717273747576777879808182838485 ... LastLast
Results 741 to 750 of 919
Thread: Freedom Ultimate (Worklog)
  1. #741
    Newbie rationalpi's Avatar
    Jan 2006
    Shelton CT
    has there been any word on a new version of this skin?
    Planning: [==========] 100%
    Software: [======-----] 50%
    Installation: [========---] 70%
    (WorkLog) (Pictures)
    "Censorship, like charity, should begin at home; but, unlike charity, it should end there." - Clare Booth Luce
  2. #742
    May 2006
    Calgary, Alberta
    I'm wondering if the video player skin can skip between videos when hitting Next/Prev instead of searching through the video. What do I change for this?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  3. #743
    Low Bitrate crispyrabbi's Avatar
    Nov 2006
    Sweden
    Siad by Guino:
    anything is changeable on any skin... just add this to your exectbl.ini:
    "PREV","DOWN",video_player.skin
    "NEXT","UP",video_player.skin
    By myself:
    It just changes so you can skip tracks in the videoplayerskin in the main menu skin I do not know.
    AOPEN MINIPC 945 VXR, CORE DUO T2400, 512MB, 120GB, Wlan, CARNETIX CNX-P1900, 1020TSV TFT 10.2" Touchscreen, BU-353 GPS, wlan-antenna, X3 integration to HU, D-link DUB-H7 USB 2.0 Hub, Wireless RF-keyboard, Logitech USB noicecancelling mic, NV RVcam
  4. #744
    May 2006
    Calgary, Alberta
    Quote Originally Posted by crispyrabbi View Post
    Siad by Guino:
    By myself:
    I added:
    "PREVTRACK","DOWN",video_player.skin
    "NEXTTRACK","UP",video_player.skin
    to execTBL and it didn't change anything.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  5. #745
    Nov 2006
    Sweden
    Quote Originally Posted by Maheriano View Post
    I added:
    It should be:
    not:
  6. #746
    May 2006
    Calgary, Alberta
    It should be:
    not:
    I should have followed the directions exactly, worked perfect. Thanks.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  7. #747
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    All based on 0.4
    • See ** - The browse by album art some times hangs the skin ( but not flash ) especially after a hibernation.
    • I've got a MP3 file with a very long TAG... I've noticed the text goes over the menu button ( ie Audio ) on the main screen rather than behind - I've scince noticed this on the audio screen too.
    • Under the web browser if you use a very long url ( eg the project I showed you cdr ) you cant see what your typing as it goes off the screen once its reached the full length of the URL entry box rather than shuffle accross....
    • Where you have lower buttons change ( ie from web to volume etc ) is there any chance you can add the following on the web browser ?
      1) Online / Offline Indicator ( I guess a simple ping will do )
      2) A dial up connect button
      3) A dial up disconnect button
      4) An option for Auto or manual
      ( Some info on that here http://www.mp3car.com/vbulletin/soft...-required.html - The code shows you the command line needed for both. )
      I see the web browser autoconnects now but It some times has if you have it started ( The web app ) and then move to another screem and hibernate but dont have your phone one you. Sort of hang around for ages once you restart. May be if you can through in the option to run a command first too for those of us that use BT ?
    • See ** - Any one got the EQ to use the presets / save the presets ? I have a few I want to use but I just dont seem to get them to work even though the EQ does.
      More info - Tested just now. If you press and hold the preset it updates it but saves it so that if you press any of the other eq presets the same comes back - ie one setting for all the presets. Also had a hick up where after a while ( I was waiting ) it went to the main screen and turned the volume up full. When I when back it would not let me check the EQ manually let a lone by the presets.
      See ** - WORK AROUND - I got it working - But I know the issue. Yes you can set and save but if you dont exit out the screen and then go back in you cant use them / wont update the screen. To fix - do youor settings then go to the main screen THEN test them.
    • I did this under the Title section in rrconfig and I cant seem to get it to work... am I been dim ?
      "%title%***%genre%"
      It still shows undefined underneath... and I know all my MP3s are sorted as well this time.
      ** Update ** - Tags show ok in genral on 03 - is this an ID3 / ID1 tag its looking for ?
    • Skin support for Webmasters GPS Tracking app - http://www.mp3car.com/vbulletin/gps/...-tracking.html ( Gatso Huter & Traffic Cams Done Already )
    • Skin support for ICE radio plugin with more advanced features for the Silabs
    • See ** - On my 12000 runs a lot slower than 0.3 - a lot. Although I dont get the same scripting error message I posted a while back. Screens tend not to change and a reset is needed ( ie mixer to main ) or they take for ever.
    • Album Art image for Radio
    • Screen Saver while on Radio ( like the Audio section )
    CDR - Any upates ? Would any bribery work at this point ?
    Update 060807
    ** = Well, I've been using all the speed & transistion options enabled for a week now. Bar the fact its a tad slower for obvious reasons its not failed on me yet, even the EQ works as it should.
    So - on that basis I'd say there is some coding some where that needs looking at for the cut down versions.
    OK - been using with CPU speed fast and transitions off. Its ok for abiyt 3 hibernations and then sort of hangs but the machine is still running... in fact so is the skin but with no control over RR. Its even worse if using FD 1 and you exit the GPS screen as they always does hang.
    Now trying with the transitions on fade & CPU speed slow.
    Terran
  8. #748
  9. #749
    Jun 2007
    If there is someone interested in...I made my own "CarPC Status"-Screen in Flash for FU. It uses sensor data from "MotherBoardMonitor".
    Just unzip the files from "status.zip" to your own FU skindir.
    After this you have to setup the MBM sensors in the "status.ini"
    (usefull: http://guino.home.insightbb.com/MBM-Sensors.zip)
    In the "rrscreens.txt" add something like:
    &screenstatus=CarPC Status&
    To select the Status-Screen you have to add an additional Menubutton in "menu.txt"
    &mainbut13=Status@icons\settings.png@LOAD;status.s kin&
    EDIT:
    Sorry, I've forgotten to add "status.skin" to the zip-package.
    In this file you have to add/modify the last labels corresponding to your status.ini.
    L,0,0,0,0,0,0,0,0,"arial","CPU","0"
    L,0,0,0,0,0,0,0,0,"arial","FREEMEM",
    L,0,0,0,0,0,0,0,0,"arial","ALLMEM",
    L,0,0,0,0,0,0,0,0,"arial","ALLFREEMEM",
    L,0,0,0,0,0,0,0,0,"arial","TOTALMEM",
    L,0,0,0,0,0,0,0,0,"arial","MBM01","0 C"
    L,0,0,0,0,0,0,0,0,"arial","MBM02","0 C"
    L,0,0,0,0,0,0,0,0,"arial","MBM33","0.00 V"
    L,0,0,0,0,0,0,0,0,"arial","MBM35","0.0 V"
    L,0,0,0,0,0,0,0,0,"arial","MBM36","0.0 V"
    L,0,0,0,0,0,0,0,0,"arial","MBM37","0.0 V"
    L,0,0,0,0,0,0,0,0,"arial","MBM49","0 UPM"
    L,0,0,0,0,0,0,0,0,"arial","MBM65",
    Ciao
    Attached Files Attached Files
  10. #750
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    cool can you make one for the silab new radio plugin
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 10:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 12:40 PM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
