:-) pm sent with FU Alpha link..
cheers m8
CdR
Ill help out for sure bud, im so excited about this realese!
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
cheers m8
CdR
Thanks CDR ill get on it tonight!
my TURBO! Altezza!
Just from my test
Were does the speedo information come from? Is there a plug in for roadrunner?
Visulastions arn't there.
Couldnt change the web address when browsing.
Options to disable track number from apparing , its a real slow down on my epia 1300
but overall its faster than freedom was.
AWSOME work it is a dream come true for me! Best skin to date! The audio interface is great just a little slow because of the fade in of the songs but thats about it everything is fast setting screens work well!, I understand what u meen about freephone hopefully can integrate something with OBD2 there!
Love your work!
Keep me posted Im going for a drive now so ill see how it handles with a turbo crankin!
my TURBO! Altezza!
Hi m8, thanks for the feedback..
The gps comes from roadrunners gps settings in its rrconfig. It all depends if your using a application that can update roadrunner itself (freedrive / mapmonkey) or you will need to use a com port splitter to split the info coming from your gps device.
The vis at the mo is only on the audio screen (click the logo top right)
The Webbrowser is built for touch screen, so if you tap the new at the top you can then enter a address, if you want to enter text on a webpage.. ie in google to search, tap the searchbox first to give it focus, then tap the keyboard at the bottom.. to set home / mail or add a fav, goto the page you want and press and hold the button and it will add it.
I will be adding more options soon to remove effects so it will run more smoothly on lower end machines.. these again will be added to the settings menu (press clock on any skin)
cheers fella
keep ideas coming
CdR
it would be really awesome if you maybe released like two versions. one for higher end users and one for lower end. my pentium 4 with hyper threading needs a challenge
these will be options in the settings, so you can turn transitions on and off.. only one version needed then :-)
CdR
Ok one idea that is be on my mind for a while.... a internet radio,potcast player,shoutcast or whatever they call it this days. (and before gizmo jumps and say he did it with a mod of RR, I'm talking about something like the internet radio on SD but with the ability to enter URLs yourself too)
Thanatos.
Shuffle of music videos, If you use mpclassic that seems to take focus and you cant use keyboard shortcuts to increase decrease volume, cant use the inbuilt player because that crashes. Web browser works well but didnt seem to want to goto my gmail! lol!
Ill keep posting ideas as I come up with them , the audio browser is great!, mabey you could make it on the main screen you could change the possition on the song on the progress bar =)
my TURBO! Altezza!
