Page 88 of 92 FirstFirst ... 38787980818283848586878889909192 LastLast
Results 871 to 880 of 919
Thread: Freedom Ultimate (Worklog)
  1. #871
    Low Bitrate mrcanngo's Avatar
    Jun 2006
    Vancouver
    Try this:
    posted by EPHECT on pg 55 of this thread
    OK ppl, another fix/setting
    Got DVD working fine using powerdvd, and i've moved the Radio from the first screen (i dont use it) and put DVD in its place, so its on the first page, button 3.
    Change or Add the below line in menu.txt
    &mainbut3=DVD@icons\dvd.png@LOAD;powerdvd_playe r.s kin;C:\Program Files\CyberLink\PowerDVD\powerDVD.exe;DVD&
    NOTE: &mainbut3 is the button location
    this will work the same for windvd, just change the location
    PS this may have been covered before, cant seem to find it.
  2. #872
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Thank you for your answer. I managed to make a button which opens the external DVD player skin. Power DVD also opens but something goes wrong. I don't know what exactly is going wrong but no DVD gets played and the mouse cursor keeps jumping into the upper left corner. I can only exit by pressing CTRL, ALT DEL. Any clue what causes this?
    I'm also integrating Destinator 7 into the UF skin. I managed to start Destinator 7 from the 'main menu', but when Destinator 7 opens it does not open in the window in which it supposed to be opened, but shifted a bit to the lower right corner. Strange thing is that Destinator 6 opens correctly (not shifted).
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
  3. #873
    Jun 2006
    Vancouver
    For your destinator issue, make sure you have your rrconfig setup properly. I dont have it installed on this computer but in the "GPS" section i believe, there is a "window" section that you have to type the "Destinator 7" name into.
    The reason it probably works for version 6 is because it already has the window "destinator 6" typed into it. Find that and replace it with the exact name of the destinator 7 window name.
    To find the window name, just look at the top of your destinator window and it should say something like destinator7 or Destinator_7. I dont know as i dont have that software. That should fix it though.
    Can powerdvd run fine with a dvd movie in it without going through the frontend? If so, do you have any keyboard inputs that might be pressed? Maybe you have to recolaborate your Touchscreen.
  4. #874
    Feb 2007
    Im certainly no expert but from what i understand D7 is very different from D6 as regards what has to be done to embed it, i believe you need a "wrapper" http://www.digital-car.co.uk/forum/s...ead.php?t=8729 all is explained here
  5. #875
    Mar 2005
    THNX a lot both of you!
    I tried different names before, but they all didn't work. I seemed to me that something else than the window name was wrong. I'm going to find out what that wrapping thing is.
    BTW: How can I find out what the real window name is? I think this will come in handy when I'm trying to integrate a DVD player.
    My Car PC project
    FD & MM voices
  6. #876
    Mar 2005
    Hi,
    I'm using D7wrapper now and I figured out how to shift the screen position into the location I want. When I start D7wrapper Destinator opens exactly where I want. But when I open D7wrapper via the FU in RR I got the screen as depicted below. It looks rubbish. Any Idea how to fix this?
    It seems that Destinator opens in the reserved area, but directly after that the screen jumps a bit down and to the right.
    My Car PC project
    FD & MM voices
  7. #877
    Mar 2005
    Not much support here anymore
    I saw several screen shots of the FU skin which have some kind of logo in the upper right corner. In my FU skin this logo does not appear. Do I need to configure something?
    My Car PC project
    FD & MM voices
  8. #878
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Fu Fu Fu Fu Fu Fu..
  9. #879
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    Fu Fu Fu Fu Fu Fu..
    How the hell can you misspell FU?
  10. #880
    Oct 2006
    Quote Originally Posted by CdRsKuLL View Post
    the logo location is stored in the skin.ini ... think its just called logo.. , just point this at your new logo (check out the ones in the logo folder to get the right size.. )
    ta
    that should help you out with your logo problem.
    i got my dvd player skin to work. sort of. im using windvd. it loads up the skin with the buttons, and then windvd loads up. it plays the dvd fine but i see the windvd frame around the outside. is there a way to hide this without manually going to full screen everytime? cant find anything in the options screen to hide it. it looks fine when im in full screen mode but to get there i have to click on the playing movie once to get rid of the skin buttons and then again to go full screen.
    also when i exit the dvd skin, my mouse cursor disappears untill i exit roadrunner.
    any fixes for this?
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 10:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 12:40 PM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
