Page 89 of 92 FirstFirst ... 397980818283848586878889909192 LastLast
Results 881 to 890 of 919
Thread: Freedom Ultimate (Worklog)
  1. #881
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    How the hell can you misspell FU?
    Long story - When i first replied, i thought i had typed that string capitalized but it showed-up as it is right now; so it made me doubt i had capitalized it in the first place so i decided to fix it and the closest reason for editing that i could think of was "spelling", however when i submitted the post again - low and behold, it showed up like that again meaning i had spelled (capitalized) it right the first time. Decided to leave it like that to see who's watching.
    Guess it's some forum control for people yelling. Learn something new every day.
  2. #882
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Replace UF = FU. Can you help me now? Whatever. You know what I meant.
    Thank you Dan95five0. I searched for a skin.ini in the FU folder but there is none. I can make one myself, but I don't know how the 'code' should look. Can you give me an example?
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
  3. #883
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Erwin View Post
    Sorry, just pulling your leg
    Look again, you should have a skin.ini
    The image you want to show should go in the logo folder and then change the line in skin.ini
  4. #884
    Mar 2005
    Thank you Treetop777
    I really do not have a skin.ini in the 'Ultimate' skin map. I do not know what version of FU I have. I may have an old version. I downloaded the skin from post 855 in this topic because the skin is not available anymore on this site: http://www.freedrive.co.uk/forums/lo...ks.php?catid=5.
    I've tried to make it work by making my own skin.ini file and added the following line:
    &logo=logo\freedom.png&
    Unfortunately it doesn't work.
    Where can I find the latest complete version of the FU skin?
    My Car PC project
    FD & MM voices
  5. #885
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Hello. I'm just trying this skin on my new system and it looks very cool!!
    I noticed some issue, don't know if related to some missing configuration. The first issue is that I cannot see the video list, just a black page but when I click on some point in the black space I select a video... So it seems to be some visualization related problem. I have the same issue for audio when I select "browse by filename".
    The second issue is GPS related. I can correctly see the gps signal and compass but when I enter the gps page I see nothing than the FU frame containing the windows desktop!! I'm using sygic drive and it works correctly with the crystalblue skin.
    Finally I'm unable to switch videos in full screen; double clicking in the video area have no effect at all.
    Any idea or suggestion that can solve these issues or can point me in the right direction?
  6. #886
    Dec 2008
    Just wondering if anyone can help me with some issues in FU. The middle section of some of the pages had shrunk which left two parallel white lines running along the top and bottom of the middle section.
    I have tried to change the values in the menu.txt but with no luck
    Please help!
  7. #887
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JoseJag View Post
    Please help!
    Re-install and if it still happen, update flash.
  8. #888
    Dec 2008
    Thanks treetop,
    I've re-install several times that i even re-install RR. I also download shockwave from one of the links given here on this forum but still no luck.
    Also, volume number doesn't change with increase or dercrease in volume
    I really like this skin and i wonder if anyone else if having same problem
  9. #889
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I Cdr
    I don't found the link for to download your skin
    Thanks for this
  10. #890
    Constant Bitrate ephect's Avatar
    Jul 2007
    Melbourne, Australia
    Please help!
    Quote Originally Posted by treetop777 View Post
    ^^ theres ur answer ^^
    update flash and it will be fixed, i had the same problem.
  1. Freedom Skin v2.1 and PowerMate..
    By Serfio in forum Input Devices
    Last Post: 06-02-2008, 10:16 PM
  2. 2003 VW GTI Worklog!
    By pogitalonx in forum Worklogs
    Last Post: 02-12-2008, 03:03 PM
  3. cf skin freedom
    By corsab in forum RR Skins
    Last Post: 10-13-2006, 12:40 PM
  4. Streetdeck project in the worklog section...
    By Mickey21 in forum StreetDeck
    Last Post: 07-11-2006, 03:00 PM
  5. Mac Mini project in the worklog section...
    By Mickey21 in forum MacCar
    Last Post: 07-10-2006, 02:43 PM
