Results 1 to 10 of 16
Thread: Help me about nRoute skin
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    Hi!
    I try to make a skin for nRoute in RR.
    the nroute window is correctly embedded.
    i want to make a "MENU" skin :this is my skin command
    B,3,129,67,90,"MENU;nRoute_menu1.SKIN"
    the menu skin is working great, but the nRoute window is disapear in the main gps window....
    could you help me WHY?
    thanks in advance
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Check for a clipping command in your skin and remove it.
    You want only the A definition.
    Nov 2006
    Hungary
    Sorry I don't understand it... could you send/write the right command?
    /EFFECT-1 ??
    Feb 2006
    Open your .SKIN file in a text editor.
    Somewhere you will see lines like:
    /, A, x, y, w, h, color;RGB
    A01,0,40,800,440,0
    /, C, x, y, w, h
    C01,0,40,800,440
    The numbers will be different but the lines will start with C or A.
    Remove the C line. Save file.
    Nov 2006
    Hungary
    THIS IS THE FIRST SKIN FILE:
    MEDIACAR Skin
    MEDIACAR "ExternalGPS" Skin
    /EFFECT -1
    /, I, x, y, w, h, Code;INDICATORCODES
    I,594,534,99,64,"MASTERMUTE"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B,1,537,165,63,"MAIN","Menu"
    B,185,537,106,65,"PREV",
    B,292,537,98,65,"PLAY",
    B,393,535,98,64,"NEXT",
    B,494,539,98,60,"VOL+",
    B,695,533,97,65,"VOL-",
    /, A, x, y, w, h, color R;RGB, G, B
    A01,80,91,719,436,000,000,000
    /, C, x, y, w, h
    C01,80,90,719,436
    B,4,217,67,91,,
    B,4,311,67,91,"ACTIVATE;nRoute||SENDKEY;{ }",
    B,3,129,67,90,"MENU;nRoute_menu1.SKIN;Menu1",
    THIS IS THE SECOND SKIN FILE:
    MEDIACAR Skin
    MEDIACAR nRoute_menu1 Skin
    /EFFECT -1
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L,225,130,112,34,255,255,255,12,"Arial",LEPKE,
    B,78,24,160,72,"LOAD;EXTERNAL_find.SKIN;None;a.bat ;Find Places||SENDKEY;^f||ESC",
    END
    I remove from the first skin C line and the result :
    confused....
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Like EricE says, remove those lines
    /, C, x, y, w, h
    C01,0,40,800,440
    or add the line
    enableclipping=false
    to RR.ini
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    is it just me or does it look like Nroute is NOT embedded right.. you can still see the toolbar.
    Live mp3Car Facebook Chat
    Nov 2006
    Hungary
    it is embedded right.
    I REMOVED
    , C, x, y, w, h
    C01,0,40,800,440
    enableclipping=false to RR.ini
    SAME RESULT
    Woodbridge, VA
    Blog Entries
    55
    the more i look at it the more i say its not embedded with the proper window name. You can see the title bar PLUS in your screenie you can see the desktop behind rr (above nRoute, the crack where your desktop icons are showing). Either i'm right or you've done something that noone else has done lol
    Nov 2006
    Hungary
    The "You can see the title bar PLUS in your screenie you can see the desktop behind rr " problem is solved. I remove the C line, but in the menu skin isn't work right
    RR ini has this line :enableclipping=false
    if i send you the 2 skin file could you correct it?
    i'm very confused....
    Attached Files Attached Files
  1. New skin
    By Floatingpi in forum CF Skins
    Last Post: 12-22-2007, 01:31 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Replies: 4
    Last Post: 11-29-2006, 02:57 PM
  4. Replies: 2
    Last Post: 11-21-2006, 04:22 PM
  5. Skullster Skin.. Please help me finish this skin
    By CdRsKuLL in forum RR Skins
    Last Post: 08-05-2005, 09:37 PM
