Results 1 to 10 of 11
Thread: Video on 1 of 2 screens
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    Right, I run a dual monitor setup with the screens essentially stacked on top of one another. Monitor 1 is my Lilliput touchscreen, and monitor 2 is in effect the other 7 screens in the truck, although it is only my Pioneer head unit that is active when I am driving as i have that set up with various flash guages. Here's a pic (only one I could find right now).
    The skin is 1024x1536 so that it covers both monitors. The problem I have is that when I go to the video screen, it is stretched across both monitors. Is there a way to define the width and height of the video player itself. I have tried modifying the video player screen in the skin, but that only applies to the panel of controls, not the actual player.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    user CDR new program. you are able to adjust the screen.
    Nov 2005
    Toronto, ON
    which one, his dual screen GPS program?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Did you have an A line (/, A, x, y, w, h, color;RGB) in video_player.skin?
    You probably need that.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jun 2006
    Houston, TX
    check here
    Second Screen GPS..
    Nov 2005
    Toronto, ON
    Yes, I have seen cdr's app, but that is not what I need. I tried adding in the A line, and it works as long as the video menu is there, but as soon as it hides, the player stretches again.
    Raw Wave
    Jun 2004
    On the beach
    Sounds like something is set to go to full screen after a the video menu disappears, check your video settings, do you use the built in player or external?
    Nov 2005
    Toronto, ON
    i believe I hav eit set to built in player. how does one change this fullscreen setting??
    Mar 2007
    My suggestion is don't use full-screen. Instead, have the full-screen button open a new .skin file which has the A? application area set to appear full-screen on one of the monitors and then you can put whatever you want on the other monitor.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    set the a line and untick video auto hide (video section) in rrconfig
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 11:45 AM
  2. Headrest screens look rough and video will not show
    By jac1502 in forum LCD/Display
    Last Post: 06-10-2006, 09:38 PM
  3. video wont display when entering video mode ?
    By Coldfusionpower in forum LCD/Display
    Last Post: 05-21-2006, 12:36 PM
  4. Extreme video playback choppyness with HVAC software
    By Dexter in forum Software & Software Development
    Last Post: 04-11-2005, 01:24 AM
