You know. I noticed that variable in the config, but didn't even think about implementing it when I was doing all these recent changes.
I guess I'll come out with another update pretty soon then.![]()
guess the last RR and RRConfig updates introduced a new variable
it's called backgroundpath
can u imagine what is it meant for?!
heheheheh
guess all the new generation transparent skin designers can benefit of a standart BG path
and so, do we
[]s
Sure did "Work" with the latest RR![]()
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
The DL link does not work.
My server uses dynamic DNS, so sometimes the IPs don't update as quickly as they should. I'm headed home for lunch now anyway, so I'll have it fixed in about 20 min. Also, I'll try and get a mirror up and running.
Should be working now. If the first link doesn't work, try the RapidShare mirror.
The 2 links are working fine now. But I dont have any pictures at the album show. Do you know why?
Do you have album art .jpg files in the folders with your mp3s?
If you do, then no. I don't know why it isn't showing up. I haven't done anything different with SE than other people have done with their skins to show album art.
If you don't, then you need to download the album art for each album and have it in the folder with those audio files.
It is in all the skins. I'm sitting on a new PC and just DL the RR and the album art does not work. But it works fine on my other PC. What have I forgotten to install?
Make sure that you have the line coverfile=*.jpg in RR.ini. If it works in SE2.1 on one computer but not the other, then its most definitely a config issue not a problem in the skin.
