Any chance a skin coder could grab BMV2 by the scruff of the neck and do the "transparency" thing on it.:pray:
After all it is the default RR skin............please ?
Printable View
you don't need a coder, you just need someone with Photoshop to grab the PSD's and change them.
Anyone up for it ?
Actually you will need to make changes to the existing code & add some new code in addition to saving the jpegs as png. Are the PSD's available for BMV2? It also depends on how the PSD file is layed out to determine if the picture work is going to be easy or worst case scenerio, need to be completly re-created. I have to agree that as the base skin for RR it probably should have the transparent feature implimented.
