Results 1 to 8 of 8
Thread: Background
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    Background
    Everyone is starting to skin with the clear background which rocks. but i'm having a hard time coming up with a background that i like. so i was thinking what if the background was your audio cover. I'm not any good at writing code, but i have an imagination. Not even sure if this is possible? Any thoughts, or anyone willing to give this a shot. Most of my album covers are 500x500 so quality shouldn't be an issue. Posted before and an idea.
    Thnks.
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    sounds like a flash job to me. this is easily possible with flash right now, but im not sure how well it would work with guino's current set up.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Won't work w/o flash. The album art will disappear under a button.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Mar 2006
    Houston, TX
    Quote Originally Posted by Sal R. View Post
    not if your button is partially transparent
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    you can't change the background for the .skin file you are in without going out of that .skin file and either reloading the skin or have that as a /discardable skin in which case you would have to go out of the .skin and then back in again.
    And have to do that everytime the song changed.
    Mar 2006
    Houston, TX
    Quote Originally Posted by Enforcer View Post
    again, unless you are using flash, in which you can just layer your album art to be behind a transparent playlist.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by tundra2000 View Post
    I was referring to the non flash version
    Mar 2006
    Houston, TX
    yea i know i was just bein a jerk. you are right tho
  1. Transparent Background XM Art
    By cletus323 in forum FrodoPlayer
    Last Post: 02-27-2005, 01:55 AM
  2. change color of windows startup background?
    By aoLhaTer in forum Software & Software Development
    Last Post: 06-17-2004, 11:16 AM
  3. 3d background for Front-end software?
    By 99bravada in forum Software & Software Development
    Last Post: 12-21-2003, 06:04 PM
