Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 143
Thread: Shock Skin v4 Transparent Released
  1. #21
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by C4DAO View Post
    I then checked my playlist direction "E:\Playlists" and rrr.m3u is in there, but again it doesn't show up anywhere in RR?
    Try this. Add the following line in rr.ini
    audiofiles=.m3u,.mp3
    I went into the MP3 menu and selected visual, and you can see the visual display pop up behind the winamp playlist. Clicking it brings it to the front but it cannot be dragged, although you can right-click it to access the various options. Shouldn't it automatically embed?
    Later versions of winamp5.x has had problems w/ the vis embedding properly.
    2.95 is tried and true.
    I'm using 5.13 and works fine.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
  2. #22
    Constant Bitrate C4DAO's Avatar
    Apr 2007
    Cardiff
    @ blk02si / Sal R
    Thanks for the advice - sorted it now. Path for my playlists was defined correctly, but the music path wasn't.
    Still can't sort out the visual plugin, so I've gone back to the standard AVS - looks fine!
    Thanks again for all the help!
  3. #23
    Jan 2006
    Montreal, QC, CA
    Nice !. Now i have homework to do.
  4. #24
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    The skin works great, very easy to change button labels and button commands using the skin editor. I did change that bit of code for the playlist skin (to the rr playlist variable) and it works great. (Screen cap is via VNC so the quality isn't perfect)
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #25
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Looks good chevy, I like that background. Im glad to see people taking advantage of the new code and features.
    Q. for Sal
    Do you think it would be ok to define the label colors like this example:
    L,712,3,74,45,#R#,#G#,#B#,30,"ISOCPEUR:B","=SET"," CENTER"
    Then have SHOCKCOLORDEFINITION.txt look like this:
    /,Shock Font Color
    /DEFINE R 255
    /DEFINE G 255
    /DEFINE B 255
    Its the same code just simplified a bit (- the shocks). Now what typ of app or how do I go about picking a color from a menu and having it write the RGB values to the SHOCKCOLORDEFINITION.txt?
    Hand editing would not be bad because those 3 values would be a global color definition on the skin labels, but adding a simple color selector would be really nice. Im going to do some research into this and add a menu_3 for testing and building this color code.
    Also here is a screen cap of the analyzer configured running the audio_gps.skin
    Keep the screeners coming!! love to see different contrasting backgrounds on other peoples builds.
  6. #26
    Jan 2006
    Montreal, QC, CA
    Looks good, but you should had animated gif
  7. #27
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    a friendly advice, would be good idea to make a patch for iGuidance, to remove all the buttons not needed, or make them match to your skin, like lsxvoid, and some more skins out there have.your skin is getting very popular so why not, i can see sal is giving you some very good advices.
  8. #28
    Oct 2006
    small town nebraska
    Just for fun I added a big visual skin with the controls at the bottom (I'm learning some basic skinning)...the center of the main menu loads it.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  9. #29
    Jul 2005
    Motorcity
    Blog Entries
    1
    I use LSX's patch in the car. This screencap is from my freshly formatted desktop
    iGuidance is very tedious to skin, I wish there was some sort of batch program to simplify, I just don't have it in me to go through 300 some odd bitmaps using resource hackers clunky interface to swap em out.
  10. #30
    May 2006
    Quote Originally Posted by Sal R. View Post
    Changing label colors is actually very simple.
    For example.....
    another way to do it, which is a bit more versatile......
    Add to each .skin file an include...
    INC,whatever.txt
    in whatevr.txt define the colors rgb values...
    /DEFINE ButColor 239,245,188
    /DEFINE ListColor 108,234,140
    /DEFINE FoldColor 87,188,135
    /DEFINE HLColor 248,160,71
    /DEFINE BKGColor 49,42,35
    /DEFINE IndColor 248,160,71
    /DEFINE ItemColor 248,160,71
    /DEFINE GroupColor 239,245,188
    now in each skin file you can use these variables as rgb values...
    L,600,3,74,45,#ButColor#,30,"ISOCPEUR:B","=APP","C ENTER"
    L,484,3,74,45,#ButColor#,30,"ISOCPEUR:B","=VID","C ENTER"
    L,357,3,90,45,#ButColor#,30,"ISOCPEUR:B","=NAV","C ENTER"
    L,244,3,89,45,#ButColor#,30,"ISOCPEUR:B","=SAT","C ENTER"
    L,120,3,98,45,#ButColor#,30,"ISOCPEUR:B","=FM","CE NTER"
    L,13,3,85,45,#ButColor#,30,"ISOCPEUR:B","=MP3","CE NTER"
    L,11,340,136,63,#ItemColor#,48,"DS-Digital","VOLUME","LEFT"
    L,2,74,344,30,#ItemColor#,18,"ISOCPEUR","AUDIOTRAC K","SCROLL-LEFT"
    L,576,342,216,62,#IndColor#,48,"DS-Digital","TIME","RIGHT"
    L,658,76,137,28,#IndColor#,18,"ISOCPEUR","DATE","R IGHT"
    Now you can change ALL the label colors by editing whatever.txt and you can have different colors for button labels, lists, indicators, scrolling text, etc....
    each define takes the place of an rgb group in the skin file, so playlists would look something like this...
    S01,217,89,522,382,#ListColor#,#BKGColor#,#ListCol or#,#BKGColor#,#HLColor#,TRUE,25,"Neuropol:B"
  1. New Age ... RELEASED ... Transparent
    By ThunderStick in forum RR Skins
    Last Post: 09-24-2007, 12:10 PM
  2. Replies: 145
    Last Post: 09-09-2007, 11:38 PM
  3. Shock Skin - v1.0 & v2.0
    By blk02si in forum RR Skins
    Last Post: 07-28-2007, 09:59 AM
  4. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
