Nice work crooper! I remember you mentioning you were working up a static clock and such. Layout looks really good, actually gives me more ideasand that why I share. I really wanted this skin to be simple to modify and its great to see customized versions being posted. If you need hosting to share your modded code base let me know.
pwntbypat, you can code the back button to always return to main menu if that suits your use. Just need to change the command on each screen.
There was some things I really liked about v3 and had a feeling some people would like it better than 4. Version 4 is just plain out quicker on my via though.
On another note I finally configured Xport on my carPC to share my GPS between RR and IG. I am thinking about adding some more speedo labels so I know how fast im going when im looking at the PC and not the road.
Xport was tough to get it running at boot since my XPE build had RR set as shell. I ended up using the autostart function in RR to launch xport even though Im still trying to find a way to launch it on an OS level. Since explorer.exe is not set to shell I could not get XP to auto start Xport on boot. Still need to tweak some things but my INFO screen up up and working good. Im thinking about changing the header label to a picture/arrow style heading.
LinkBack URL
About LinkBacks
