Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 89
Thread: BLACK & WHITE_APPLE 800x600 & 800x480 released
  1. #11
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    GF-ler,
    I haven't played around with the coverflow app -- other than to see if it basically worked (ie: I haven't created the xml file yet). However, it does work and it does seem to be fairly smooth. That said, look at my system specs -- they are pretty hefty. Assuming it stays the same once I add the xml file, then yes -- I would say it is very cool. It may not figure into how I plan to organize my music, but that determination is a little down the road...
    As far as IG4, I figured you OLD-EUROPE folks wouldn't know anything about IG. But I saw your initial post and thought I would ask.
  2. #12
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by nasa View Post
    GF-ler,
    IG2.12 is the last europe version they build... and i work with it.
    all other, on pc/laptop working navis are not so good.
  3. #13
    Jul 2006
    Sexy Taiiimeeee
  4. #14
    Jul 2006
    unfortunately the whole skin shows up blank when i load it up on my home or carpc. if i roll my mouse around, ill see buttons and borders slowly popup...
  5. #15
    Aug 2005
    germany
    Quote Originally Posted by hari-bhari View Post
    only for i installed the newest Road Runner..... and it runs.
    in german we have a name for it.
    thousands are sitting in the stadion, who gets the ball ???? YOU !!!
    dont know whats your problem with the installation, but you have big one.
    first the graphic of Simplistique didn't work, now the same graphic problems.
    a simple call of a .png screen didn't work on your machine. there is no mystic code in the skins.
  6. #16
    Aug 2005
    germany
    The Final Cut is on the way.
    the screen is for 800x600 mainly IGuidance, transparent and WITHOUT font and colour changing.
    make some graphic changes, new icons for more different way to work with IGuidance and audio Browser. If i know how the IList stuff works it gives an update.
    not ready is the calendar with the ToDo list and switching.... month/year fw/rw.
    it gives also a DAY and a NIGHT version of it.
    the Night version is 98% ready and i think next days i give a link in post 1.
    see post 1 for new skins
  7. #17
    Jul 2006
    yes but its happening on two separate pcs with two completely different installations. ill try a clean wipe and do it over.
    by the way, the skin looks GREAT!!
  8. #18
    May 2005
    Vienna, VA
    This skin looks awesome. I think I just creamed my pants.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  9. #19
    Jul 2006
    i found it out, it was a stupid problem. your skin.ini file was pointing to the wrong folder for me in both skins. i fixed it and it works great now!
    edit: by the way, now that its working, i noticed that the scroll position doesn't work for me. it scrolls up and down just fine, but the little indicator showing list position stays stuck at the bottom.
  10. #20
    Dec 2006
    Hey GF-ler,
    I have the same issue that Hari-bhari found. I think it could be because I am running DigitalFX.
    You mentioned a day skin, are you still continuing to develop. I would be happy to create a skin for Destinator 6.
    If you could send me the Radio Skin PSD or PNG and font I will use the button design I will create the skin.
    I have been playing with blending logo's in to the background and so far they look pretty cool. This is the one I am cuuerntly using with Iphone.
    BTW, Am also happy to help out in the development of this skin. Have learn't heaps over the last few months with regard to modifying and adding additional stuff to skins.
    AVAWONDAFULXMAS.
    Cheers
  1. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  2. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  3. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  4. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
  5. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
