Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 89
Thread: BLACK & WHITE_APPLE 800x600 & 800x480 released
  1. #71
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    xyz
  2. #72
    May 2008
    how install this skin in my RR??
  3. #73
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    GF-ler ... on your weather screen you need to make a change ...
    you have the variable "w_0day_ppcp" used twice - for both humidity and precipitation. this is the same for day's 0, 1 and 2 ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  4. #74
    Aug 2005
    germany
    Quote Originally Posted by Valheru View Post
    thanks,
    i found a lot more faults in the .skin files.
    and its not funny, because every line between a running skin (CAVE) and the apple ones is the same, only the coordinates are different.
    all around the RRMedia and the SAL.R albumcover i insert by copy and past from BlueZX3 and SAL.R application, the fine tuning i make with the editor 0.71.
    some functions didnt work correct, so i compare all lines with the CAVE one.
    yeah i use glases, but to see that theres no different between NON running and RUNNING i see without them.
    so i wrote all commands new by editor 0.5...and now the most things are working the right way.
    only Blues RRMedia didnt save me the rated song inside the database file.
    its a long time ago i had a near fault in the Simplistique skin. this time i swear never ever work with copy and paste. i think i forgot it.
    the .skin files of the dark_apple i changed, if the white apple are changed too, i put them in post 1.
    $osman
    did you read the notes.txt file ?
    is their anything you didnt understand ? if yes, lets change to PM.
  5. #75
    May 2008
    ok GF-ler
    thank you..
  6. #76
    Apr 2006
    Sydney, Australia
    r u planning to iron out the latest bugs?
  7. #77
    Aug 2005
    germany
    Quote Originally Posted by Kosti View Post
    yeah its in the make, the black one is complete, the white one in work.
    also the white apple in real 800x480.
    i do this because the rainlendar calendar and some flash things are not willing to work in stretched mode.
  8. #78
    Aug 2005
    germany
    UPDATE for the last version of the BLACK and WHITE APPLE you found in post 1.
    APPLE 800x480
    For the users of 800x480 screens i make a new one in this resolution with own backgroundscreens and own rainlendar calendar.
    These are fixed in the exectbl.ini and the skin.ini file. If you use the new roadrunner make true that it not fixed in the rr.ini.
    If you use the new RoadRunner, rename the folder to BACKGROUNDS.
    In the preview i show once without a border, but it looks better with it. Therefore i must change the graphics, Thats now done and you can load it.
    The link for it is also in post 1.
    have a look into the notes file for starting the skin.
    23 November 2008
    now the black apple in 800x480 is ready. next ours i will give a link in post 1.
    it looks a bit different to the white one.
    Attachment 52807
    Attachment 52808
  9. #79
    Oct 2007
    couple of bugs
    hi GF-ler
    thank you for your excellent skins
    i have tried so many other skin and i should say that this is the best skin .CPU usage is much less compared to others
    i found couple of bugs with it
    1.when i load a disk the volume of the pc goes down to zero
    2. i use sygic as for navigation .in almost every other skin sygic embed well without problem.i tried everything including changing the extbl.ini file.the best i could get was i can load the sygic by pressing the gps button but it doesnot resize /embed in the gps window
    so if i have to use gps i have to load a different skin
    i di read your advise in your previous post and Help - ExecTBL
    appreciate if you could look into it
    thanks
    baiju
  10. #80
    Aug 2005
    germany
    Quote Originally Posted by baiju View Post
    hi GF-ler
    thanks
    baiju
    hi baiju,
    to 1. of your post, is it when you loading a disc from the rrmedia part ?
    2. i think i must load sygic for testing, normaly its equal what kind of navigation you use.
    the only position for fixing are in the rr.ini and the exectbl.ini.
    inside the exectbl.ini its written for iguidance older version.
    but i will have a look whats going on, perhaps i get a trial version for testing.
    regards
  1. **NEW BETA Software release for XP & Vista**
    By 2k1Toaster in forum FB Software
    Last Post: 11-07-2007, 04:35 PM
  2. Replies: 70
    Last Post: 10-15-2007, 06:21 PM
  3. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  4. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
  5. RELEASE - FreeDrive 0.51 Beta
    By CdRsKuLL in forum FreeDrive
    Last Post: 04-20-2005, 05:03 AM
