Results 1 to 10 of 15
Thread: Having trouble clicking buttons w/ scrolling labels on top of it...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    So, here's a snipet of the skin code:
    Code:
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B14,155,89,492,38,"CHANGESETUPRRDRIVEPATH",
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L19,181,92,437,29,#MMITITLER#,#MMITITLEG#,#MMITITLEB#,#MMITITLESIZE01#,#MMITITLEFONT01#,"DLPATH||LISTTEXT||=\","SCROLL-CENTER"
    I can't seem to "click" the button if there is a scrolling label on top of it. With static labels, the button works just fine. However, with a scrolling label, I have to click outside the boundries of the label code to click the surrounding button.
    Is there a way around this and still keep the scrolling label?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Labels are on top of buttons, when te label scrolls it is preventing the button from beeing pushed.
    Change your button to a LABEL and put this code in.
    L14,155,89,492,38,"EXEC;CHANGESETUPRRDRIVEPATH||=" ,
    Aug 2006
    Sun Diego
    Quote Originally Posted by MGD View Post
    Copied it and pasted, but it didn't do anything?
    I even tried an existing command:
    L14,155,89,492,38,"EXEC;PLAY",
    and it didn't do anything.
    Aug 2006
    Sun Diego
    I think there's a bug on that command. An extra set of quotes is showing up after using the EXEC command.
    ExecTBL.ini:
    Code:
    "CHANGESETUPRRDRIVEPATH","LOAD;SETUPRR_CHANGEPATH.skin"
    Command1:
    Code:
    L14,155,89,492,38,0,0,0,18,"Arial","EXEC;CHANGESETUPRRDRIVEPATH",
    debug.txt
    Code:
    10/10/2007 1:51:51 PM: Que Exec: True, setuprr_skin1.skin, "SETUPRRDRIVEPATH", False
    10/10/2007 1:51:51 PM: Executing: LOAD;SETUPRR_DRIVEPATH.skin
    10/10/2007 1:51:52 PM: Leave Exec: False, setuprr_skin1.skin, LOAD;SETUPRR_DRIVEPATH.skin, False
    10/10/2007 1:51:52 PM: Enter Exec: False, setuprr_drivepath.skin, "CHANGESETUPRRDRIVEPATH"", False
    10/10/2007 1:51:52 PM: Que Exec: True, setuprr_drivepath.skin, "CHANGESETUPRRDRIVEPATH"", False
    10/10/2007 1:51:52 PM: Executing: CHANGESETUPRRDRIVEPATH"
    10/10/2007 1:51:52 PM: Leave Exec: False, setuprr_drivepath.skin, CHANGESETUPRRDRIVEPATH", False
    10/10/2007 1:51:55 PM: Enter Exec: False, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:51:55 PM: Que Exec: True, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:51:55 PM: Executing: SendMsg;RRCDRip;showplugin
    10/10/2007 1:51:55 PM: Que Exec: True, setuprr_drivepath.skin, "bye", False
    10/10/2007 1:51:55 PM: Executing: QUIT
    10/10/2007 1:51:56 PM: Shutdown
    Command2
    Code:
    L14,155,89,492,38,0,0,0,18,"Arial","EXEC;LOAD;SETUPRR_CHANGEPATH.skin",
    debug.txt
    Code:
    10/10/2007 1:53:52 PM: Que Exec: True, setuprr_skin1.skin, "SETUPRRDRIVEPATH", False
    10/10/2007 1:53:52 PM: Executing: LOAD;SETUPRR_DRIVEPATH.skin
    10/10/2007 1:53:53 PM: Leave Exec: False, setuprr_skin1.skin, LOAD;SETUPRR_DRIVEPATH.skin, False
    10/10/2007 1:53:54 PM: Enter Exec: False, setuprr_drivepath.skin, "LOAD;SETUPRR_CHANGEPATH.skin"", False
    10/10/2007 1:53:54 PM: Que Exec: True, setuprr_drivepath.skin, "LOAD;SETUPRR_CHANGEPATH.skin"", False
    10/10/2007 1:53:54 PM: Executing: LOAD;SETUPRR_CHANGEPATH.skin"
    10/10/2007 1:53:54 PM: Invalid Skin file: setuprr_changepath.skin"
    10/10/2007 1:53:54 PM: Leave Exec: False, setuprr_drivepath.skin, LOAD;SETUPRR_CHANGEPATH.skin", False
    10/10/2007 1:53:58 PM: Enter Exec: False, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:53:58 PM: Que Exec: True, setuprr_drivepath.skin, "QUIT", False
    10/10/2007 1:53:58 PM: Executing: SendMsg;RRCDRip;showplugin
    10/10/2007 1:53:58 PM: Que Exec: True, setuprr_drivepath.skin, "bye", False
    10/10/2007 1:53:58 PM: Executing: QUIT
    10/10/2007 1:53:59 PM: Shutdown
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Change your LABEL from this
    L14,155,89,492,38,0,0,0,18,"Arial","EXEC;LOAD;SETU PRR_CHANGEPATH.skin",
    to this
    L14,155,89,492,38,,,,,,"EXEC;LOAD;SETUPRR_CHANGEPA TH.skin||=",
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You can't have clickable areas when you have a scrolling label.
    I asked this ages ago.
    However if you ever get a solution to work let us know.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    just tested it and it works just fine with scroll.
    L,288,12,200,50,,,,,,"EXEC;MAIN||=",
    L,302,22,172,29,255,255,255,18,"Arial","TAGTITLE", "SCROLL-CENTER"
    MAKE SURE THE EXECUTABLE LABEL IS ON TOP OFF THE SCROLLING LABEL.
    Meaning the exact order as on top. Exec Label first then scrolling label.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Yes you do. Otherwise it is not working. Got me I don't know why.
    BTW. The all caps does mean I was shouting or yelling.
  1. Labelling buttons for an OEM look - how?
    By Gibson99 in forum Fabrication
    Last Post: 02-17-2006, 08:20 PM
  2. Rotating Labels and buttons
    By Enforcer in forum RR Bug Tracker
    Last Post: 12-02-2005, 05:37 PM
  3. playing selection via the top << and >> buttons
    By binh in forum Software & Software Development
    Last Post: 06-09-2005, 11:29 AM
  4. Clicking of buttons
    By strohj in forum AutoTouch
    Last Post: 11-02-2004, 04:58 PM
