Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 85
Thread: Shock Skin v 5.0 Released
  1. #11
    Nov 2004
    St Louis
    Quote Originally Posted by treetop777 View Post
    The backgrounds is something i've been keeping an eye on; i can tell you so far nobody has come-out with code using the background variable and a background.skin which do the same as the picviewer. I've been messing with it and the main problem is that the background you select within the skin won't change unless there is a exact copy of the BG folder within the skin - aside from the one referenced by the BG variable. In other words, if you have a BG folder in my documents > my pictures, you also have to have one (at least the same image) in the Shock folder for the BG to change..
    I will work on the weather, in fact, that's the way i was trying to do it in the beginning.
    You're right about th background.skin, but I have consolidated all my backgrounds under picspath. Here is my code that works even in SHOCK v5:
    Code:
    /Background Change Code
    B,558,294,219,92,"SETVARBYCODE;LISTTEXT;LISTTEXT||SETVAR;background;$PICspath$backgrounds\$LISTTEXT$||SAVETOSKIN;background;$PICspath$backgrounds\$LISTTEXT$||RELOADSKIN||Load;PicViewer.skin",
    I am going to try the backgroundpath later, but my code starts the background skin in picspath (my documents > my pictures) and I deleted the backgrounds folder from the skinpath.
  2. #12
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Improved Weather
    With presets. Made for V4 (can work with any othe version of Shock). Read the readme.
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #13
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thanks Treetop! Code works great. Getting to know the SETVAR command. Appreciated as always.
  4. #14
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Shock v5 works very nice. I like the settings.txt. Screenshot of the medialaunch skin...Included in the download of medialaunch. It uses settings.txt
    Launch video/dvd/cd/audio via any drive letter
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  5. #15
    Jul 2005
    Motorcity
    Blog Entries
    1
    Wow! Thats Awesome Chevyn8! I am going to take a look at your plugin, never realized it but that is a handy piece of software add in there. Can you post up your code? I am downloading it now but I see you already finished a skin for Shock. \
  6. #16
    Oct 2006
    small town nebraska
    The code is in the download. It's a little bit big to post.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  7. #17
    Jul 2005
    Motorcity
    Blog Entries
    1
    Downloaded your code chevy, This was really cool of you to add to the skin. Much Appreciation! I am still going over the readme but this will def. be added in the next release. I really like the idea of plugging in some media and having RR detect and upon your click load and play. Really nice work here, Im glad my skin ended up as an example in your download
    Also wanted to thank gizmo for the code you posted regarding the background directory. This is something that needs to be finished.
    I will be adding and testing these new features along with merging treetops new weather menu. I will have some screenshots here soon
  8. #18
    Sep 2006
    War-Town, GA.
    Outstanding BLK. Did you finish your volume mouse contraption?
    M2-ATX Power Supply
    Windows XP SP3
  9. #19
    Jul 2005
    Motorcity
    Blog Entries
    1
    Everything is finished with the exception of mounting the device. I need to find a good spot in the stang to put the knob without modifying things.
    Next time around I think I am going to get amps that have a remote gain knob instead of using the PC to control the volume.
  10. #20
    Oct 2006
    small town nebraska
    Quote Originally Posted by blk02si View Post
    Your welcome. Why your skin: Your skin is very easy to modify, especially with the latest skin editor, and you can see the background in the main screen (uncluttered).
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. Replies: 145
    Last Post: 09-09-2007, 11:38 PM
  4. Shock Skin - v1.0 & v2.0
    By blk02si in forum RR Skins
    Last Post: 07-28-2007, 09:59 AM
  5. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
