Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 85
Thread: Shock Skin v 5.0 Released
  1. #21
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    Quote Originally Posted by blk02si View Post
    Everything is finished with the exception of mounting the device. I need to find a good spot in the stang to put the knob without modifying things.
    Next time around I think I am going to get amps that have a remote gain knob instead of using the PC to control the volume.
    You could also use something like this and control the volume (before the amp)
    http://www.radioshack.com/product/in...entPage=search
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  2. #22
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thanks again chevy, where would you wire that radio shack part? I'm familiar with potentiometers but not quite sure where to place it on the wiring diagram to make it efficient.
  3. #23
    Oct 2006
    small town nebraska
    That depends on your setup. That one "should" work on the stereo output from the computer going to the amplifiers/amplifiers, as it does left/right The Nano Patch does this, but is in a box and with some more cost.
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
  4. #24
    Apr 2006
    I have a problem, the butons do not show up, only the writting on them, unless I go with the mouse over them. I had Shock V3 installed before and that one works fine. Any help?
  5. #25
    Jul 2005
    Motorcity
    Blog Entries
    1
    Sounds like a conflict in the art files. Can you explain how you have it installed? Perhaps re-extract a fresh Shock-v5.0 to a new directory and start from there.
  6. #26
    Apr 2006
    I tried version 4 and 5... both act the same. If I hover mouse over they load up, one by one. I extracted the archive and copied the folder in the skins folder.
  7. #27
    Jul 2005
    Motorcity
    Blog Entries
    1
    What version of RR are you running Brib?
  8. #28
    Apr 2006
    It's the last version. I even checked the updater. There's also no backgound, if it makes any difference.
  9. #29
    Jul 2005
    Motorcity
    Blog Entries
    1
    You need to set a background image, go to set > background > choose an image > APPLY. This will update the skin.ini file with a legit path for your system and get the background displayed. Hope this helps, if not perhaps you can post a screenshot? Also make sure that picspath in rr.ini is pointed to the 'backgrounds' directory included with the skin. This will be changed in the next release to use the backgroundpath in rr.ini as it should. If all else fails and you cannot navigate the skin w/o the background. open up skin.ini and type in a path to a background to get it going.
    I LOVE the new fading album/application art. Looks so smooth! Nice work Guino.
  10. #30
    Jul 2005
    Motorcity
    Blog Entries
    1
    Just wanted to say Thanks again chevyn8!
    Just finished integrating your media launch code and I am amazed how simple, efficient and good your script works. RR is now automated! I also really like how new buttons appear on the main menus.(screenshot posted) I am going to be tweaking it more but one question, does your script makes its decision on what type of media resource is offered by the windows defined associations if your using a flash drive?
    Really nice enhancement to functionality of RR. "Plug and Play" if you will Everything is working well on my desktop, will move it to the auto for further testing on the embedded setup
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. Replies: 145
    Last Post: 09-09-2007, 11:38 PM
  4. Shock Skin - v1.0 & v2.0
    By blk02si in forum RR Skins
    Last Post: 07-28-2007, 09:59 AM
  5. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
