Results 1 to 8 of 8
Thread: Help needed ..
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Help needed ..
    To all the designers out there ... I'm working on a transparent skin using Paint Shop Pro 7. I can create the image as I want it and then flatten it and export it using the PNG optimizer. However when I try using it in RR - I cannot see the screen.
    Can someone explain if I'm doing something wrong in PSP7 ... what exactly are the steps I need to use in PSP to correctly generate a .png file for RR.
    By the way ... RR works perfectly using any other transparent skin ... so its not the RR settings etc
    Thanks ...
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Valheru View Post
    Thanks ...
    dont know how it calls in english, but =
    save as ...
    you get rows of possible formats....
    you switch to .png ...
    and save the file.
    thats all.
    i've try it by acdSee or irfanview... no chance to get them transpart.
    Jul 2007
    Ireland
    tried that but still not working ... thanks anyway.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Does PSP actually allow you to save PNG with transparency ? that's my first question.. Flattening an image normally means making it "opaque" ... so it may just be a matter of how to save it.. but it could also be that PSP doesn't allow you to save it with transparency -- I do not know. I'd say: try to open an existing PNG from a skin and immediately save it -- see if it works normally in the skin, if so, then you can probably do it. If it doesn't work right after you save it, then you have to figure out a different way to save it, or just assume it can't be done.
    Ride Runner RR's Myspace
    Apr 2006
    Maryland
    I would also make sure you are in RGB mode rather than CMYK.
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    Use Paint.NET. Its free, and all you do is Flatten --> Save As --> PNG Format. Walla!
    Is it that it's fun? Or that it lets you forget yourself?
    Jul 2007
    Ireland
    guino : u may be right, PSP might not actually save transparent PNG files .. well not the version I have.
    Tensai : just downloaded Paint.NET and it does exactly as you say ... excellent
    Thanks for your help guys.
    Jun 2006
    Texas
    You're welcome! Good luck! We look forward to seeing some your progress.
  1. Needed, Last few Norwegian translations needed
    By veetid in forum Centrafuse
    Last Post: 06-13-2007, 11:55 AM
  2. Needed a good source 3.5mm to RCA shielded audio cable
    By bosstone74 in forum Classified Archive
    Last Post: 01-16-2006, 06:28 PM
  3. Amplifier Needed?
    By c0rrupti0n in forum Newbie
    Last Post: 03-15-2004, 04:04 AM
  4. Connect 3,5' hard drive in place of 2,5'' (dcdc for 12v needed)
    By FedorComander in forum Power Supplies
    Last Post: 11-04-2003, 08:16 AM
  5. My project for the day - advice needed
    By ddt in forum General MP3Car Discussion
    Last Post: 12-02-2002, 08:51 AM
