Results 1 to 5 of 5
Thread: fadeimages=true doesn't seem to work on non-standard skins displaying images
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    I have the following line in several non-standard image viewing skins:
    Code:
    J01,155,211,138,148,"FILE;$logopath$$imgfilename$:A"
    It does display the appropriate image correctly, but does not have fading effect that's found on the audio_browser, audio_player, & picviewer skins.
    Is there anything I can do to enable that effect?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    if thats just one image, what is it supposed to fade from or to? Does that path to the file ever change or get updated?
    I didnt know u could even use the J line for a custom image file, ive allways used the IMG tag.
    beer replenishment fund
    mp3car live search
    Aug 2006
    Sun Diego
    Quote Originally Posted by liquid_smoke View Post
    Not just for one image. It's for my icon preview skin (part of the customizeable utilities menu for my skin) that has a functionality similar to the picviewer.skin.
    Here's a portion of the skin code:
    Code:
    /,INC,File
    INC,FONTCOLORDEFINITIONS.txt
    INC,FONTSYTLEDEFINITIONS.txt
    INC,STANDARDCMDS.skin
    INC,STANDARDCMDS2.skin
    INC,THEME_ARTBOX.skin
    INC,THEME_DLSLIDER.skin
    INC,THEME_RLIND.skin
    INC,ILIST_DL_EXT.skin
    /, SD, Alignment;Alignment, Disp;MODE, Icon Width, Icon Heigth, Path
    SD,0,3,0,0,"$iconspath$","*.jpg;*.png;*.gif;*.bmp",TRUE
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B09,600,121,113,50,"PGUP||SETVARBYCODE;imgfilename;LISTTEXT",
    B10,600,171,113,50,"UP||SETVARBYCODE;imgfilename;LISTTEXT",
    B13,600,372,114,50,"DOWN||SETVARBYCODE;imgfilename;LISTTEXT",
    B14,600,422,114,50,"PGDOWN||SETVARBYCODE;imgfilename;LISTTEXT",
    B14,444,500,88,50,"UTILICONUPLOAD||SETVARBYCODE;imgfilepath;DLPATH||SETVARBYCODE;imgfilename;LISTTEXT",
    /, S, x, y, w, h, fore R;RGB, G, B,  back R;RGB, G, B,  folder R;RGB, G, B,  file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,310,135,286,326,#FORER#,#FOREG#,#FOREB#,#DUMMYR#,#DUMMYG#,#DUMMYB#,#FOLDERR#,#FOLDERG#,#FOLDERB#,#FILER#,#FILEG#,#FILEB#,#SELECTEDFORER#,#SELECTEDFOREG#,#SELECTEDFOREB#,#SELECTEDFONTR#,#SELECTEDFONTG#,#SELECTEDFONTB#,true,#LISTSIZE01#,#LISTFONT01#
    /, J, x, y, w, h
    J01,155,211,138,148,"FILE;$iconspath$$imgfilename$:A"
    You can also use the "I" code for displaying a dynamic image file using the same format above.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    J is a shortcut to an indicator, but depending on the skin it may not work with the parameter provided -- I suggest always using "I" with the parameter. (J only exists for MC compatibility). The fade effect is only set to display for coverart, albumart and picture indicators.. I'd have to create something else to make custom indicators fade.
    Ride Runner RR's Myspace
    Aug 2006
    Sun Diego
    Quote Originally Posted by guino View Post
    I tried both. I resort to "J" thinking that it might do the trick since the coverart/album art used "J."
    I have since changed it back to "I."
    Thanks g.
  1. Loadable Images Support for Skins
    By liquid_smoke in forum RR Skins
    Last Post: 08-29-2005, 01:43 PM
  2. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 02:53 PM
  3. Skins: they refuse to work! crash!
    By phatboy in forum MediaCar
    Last Post: 07-24-2004, 08:05 AM
  4. ME V1.7 skins work with ME2?
    By CelicaGarage in forum ME Archive
    Last Post: 10-24-2003, 01:56 AM
