You need the .net 2 software installed as well.
Sounds like a similar problem sonic had:
http://www.mp3car.com/vbulletin/road...arpc-help.html
Guve the suggestions in that thread a try maybe?
Cheers
Hello,
I am hoping you guys may be able to help. I have downloaded hugenius79's skin that includes HD Radio and have also purchased the Directed dmhd-1000 and mitchjs cable. So far I got the HD radio to work under Mitchjs software but I can't seem to get it to run in Roadrunner.
Here is what I have done. I have done
-opened the HDRadio Folder and ran the runme1st.bat
-added hdradioport=10 to rr.ini
-added radiomode=8 to rr.ini
When I load the FM in LSX 3.0 I hear clicks from the HDRadio receiver but nothing else happens. Furthermore, I do not see the additions to the skin. I have both copied the radio_player.skin and hd-radio.gif to the LSX 3.0 skin Folder. Lastly, there are hidden buttons just above the close button and Freq+, I can't seem to find it. I got it once but didn't know how to change the settings to an FM station.
I am hoping someone can help
Regards
Cheers
Leonardo Da Vinci
Well I have .net 2 installed in fact I did what sonic did and used unregme.cmd and reinstalled .net 2. If I am not mistaken I need to have .net 2 to run mitchjs hd player software. At this time I can use mitchjs hd player and it works fine. I just can't use it in Roadrunner
Are there any ideas why I can't get HD radio in Roadrunner?
Regards
Here's what i have in my RR.ini
hdradioport=1
radiomode=8
allowallfreqs=false
radioline=0
userbds=false
Make sure you have the latest Road Runner 11/02 the HD radio folder contents are diffrent than RR 09/29 Has a different HDradiocomm.dll file...
You will probably need to run runme1st.cmd again
Close HDRADIO PCR and before opening starting RR HD Radio ....
I had the same problem before that's how i solved it....
I never tried using port 10 though...
my first thing to tell you to do is change the port to one lower than 10.. low as possible in fact. Second thing is like the previous poster said check and make sure you are running the lastest RR release. Then check to make sure there's no hdradiocomm.dll present on your system other than the one if RR's HDRADIO folder. Open RR.ini and fix the port to the lower port you select in device manager, then run the unregme.cmd then run the runme1st.cmd . With a little luck yours will pop on just like mine did.
Live mp3Car Facebook Chat
You guys rock!!
I change the port to 9 and changed the HD Radio folder in RR. Also cleared all the hdradiocomm.dll files except in my RR HD Radio Folder
hdradioport=9
radiomode=8
allowallfreqs=false
radioline=0
userbds=false
Thanks a bunch
Ok, I have been searching the forums for over an hour now! I can find no reference to the hdradiocomm.dll or the RunMeFirst.cmd files. I did a file search of my entire C: drive, and the dll was not installed with Mitch's software.
It's not at Mitches DOWNLOAD PAGE
Its not in the RR release where HDRadio was included.
Googling for the DLL just turns up this thread!
There are only 4 posts in the all of the MP3Car forums mentioning the DLL, and just talking about it, no links to the files.
Where is this package located?
I can get the HDRadio function with Mitch's program, and have it set to the correct port in RR, as when RR starts, you can hear the relay in the radio click, and when exiting RR it again clicks.
I also have all the lines in the rr.ini such as the RadioMode=8 and such.
It seems as though I am just missing the illusive DLL![]()
My Fiero Build Thread
Leonardo Da Vinci
As Adam Savage (Mythbusters) would say.... "Well there's your problem!"
Hahhah I Beta'd RR before it was released, and just copied over the exe LOL. I guess I need to download the whole thing
That certainly explains a lot, Thanks!
John, John, John......![]()
