been 1 letter or \ in the wrong place or something simple but missable at least its working now
Printable View
Yeah, when I get more time I will print them and compare them to see if I can't find something.
I am having the same problem except I don't actually get an error message. When I click "change skin color" within the skin rr locks up. Nothing else locks up, the music keeps playing and I can ctrl+alt+delete out of rr without a problem.
I've uninstalled and reinstalled rr and the Digital 2.0 FX skin multiple times.
Anymore suggestions? :confused:
Yeah I never got an error either. It just locked and I either had to CTR ALT DLT or reboot manually. I said mine worked now but I tried it today and it once again locks up :(
Have we any thought or resolution yet?
I have compared the two ini. files. The only difference is "iGuidance". Anyone else with this problem running iGuidance?
I once again copied my laptop INI to the Carputer and woala. It worked and the skins changed flawlessley. Now, I added I guidance to the mix, and it still works. I am going to check it daily, it seems to happen after a few days...Weird huh?
Hey guys, I was having the same problem and found that if I changed my picture path to the same as my background path everything started working. I can now change my picture path without having rr crash but backgrounds will follow the picture path. Not sure if this helps, try it out, maybe it's just my config.
I was faced with the same issue, I read it as a fix in one of my searches and like you it fixed that problem. I am so pleased with this skin. It is how I actually came about finding this site. I seen a youtube video with this frontend and thought it was amazing. Hence me finding this site. We'll worth the research i have put into getting everything working.
