Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Problem with changing skin colors in Digital 2.0 FX
    Nov 2007
    Hey guys after doing alot of research on the forums I decided that I would go ahead and use the Digital FX skin, it is great with the exception of a few things, for the most part the errors are user created and this may very well be one of them lol. I have been using everything inside the program and now that I am becoming more comfortable with the program I wanted to change the skin, it locks the program. I have tried it many times, each time with the same results, attached is a screen shot. Any input would be great!
    Nov 2007
    I was just messing around in the C:\Program Files\Road Runner\skins\DigitalFX 2.0 folder and discovered if I edit the Skin configuration file I can change it to the name of any of the files in the C:\Program Files\Road Runner\skins\DigitalFX 2.0\Backgrounds folder and it works like a champ. Apparently there is either a bug with the program or just a bug with mine. I will attempt to remove and reinstall it later to see if that correct the problem.
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have the same exact problem! I have done the research and I am still clueless. I recently reinstalled and did not configure anything. I tried it and got the same result, freeze/lock up when click the 'Change Skin Color" button. I have the newest flash, I have tried it with tho old flahs method where you change 8c to 9c etc...Nothing has worked. Im in the same boat with you spyder.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Is this the background change function, the background COLOR change or the SKIN change function ? Are you both running the latest release?
    Ride Runner RR's Myspace
    Nov 2007
    PA
    This is the "Change Skin Color" button in the Settings menu of DFX 2. I have the latest versions.
    Nov 2007
    Quote Originally Posted by guino View Post
    Quote Originally Posted by Dougw133 View Post
    I am also running the latest version of both RR and Digital fx. As Dougw133 mentioned it is the Change Skin Color button in the settings menu. every single time it locks up then throws an error message.
    Nov 2007
    PA
    Well, I loaded everyhthing up exactly the same on my laptop and it worked like a dream. Even a fresh install of everything, RR/DFX on my CARPC didn't make a difference. It still hangs, and I have to reboot. I can't figure it out. Both are on XP Pro SP2, and my laptop has equal ram, only a much faster processor. Who knows??
    Nov 2007
    PA
    Spyder...Have you changed any Applications or processes for system optimization>?
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    shot in the dark
    but DL this ,drop into your backgrounds folder and try again .
    like i say shot in the dark
    Attached Files Attached Files
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Nov 2007
    PA
    Alright, I'm not sure why but i got it working. Since the setup on my laptop was working I overwrote the CARPC RR.INI with the one from my laptop and it worked fine. I slowly began to add changes (such as iGuidance etc..) and it still is working fine. So I am really not sure what happened.
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  3. "Avic'ted" - Pioneer Styled Skin
    By monkeyracer in forum RR Skins
    Last Post: 10-19-2007, 10:08 AM
  4. TO ALL SKINNERS (read this)
    By jeep642 in forum Road Runner
    Last Post: 05-01-2007, 11:23 AM
