Page 13 of 41 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #121
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    strange 1
    Quote Originally Posted by Maddominican View Post
    Ok... I'm using DigitalFX 2.2 for dayskin and LSXVoid for night. I just unzipped the files, placed the required files to the RR folder and that was it!. When I switched skins from DigitalFX to yours, it just changed the resolution to something like 300X200 (I'm just guessing the resolution because I've never seen that one, not even 640X480 was that big.) I like the skin, but it's too bad I can't use it (yet)
    it might be because you have had or have still got lsx on the system, not saying thats the problem but i have had problems after installing lsx , had to clean it right out before trying anything else.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #122
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    I too have run into issues after using LSX ... it is such a complete skin and it's installer does lots of stuff to your system. I had to fully uninstall it and clear out the RR install to get things to work after trying LSX ... I do use DFX on my system at the moment with TEK2 and there areno problems with them running on the same system..
  3. #123
    Jul 2007
    Ireland
    Bump to highlight the release of TEKNIK2 Transparent.
    This version of the TEKNIK2 skin has many features, but most noticable it incorporates a new "plugin" from El-Camino.
    This new software uses the winamp media library to store your songs ratings. Additionally you can search the media library for Album, Title, Artist and Genre. Many thanks to EL-Camino for the use of this new software, and to carputer1 who also played a big part in bringing this skin to release.
    Enjoy.
  4. #124
    Dec 2007
    Valheru, looking awsome...
    couple of things,
    - audio player does not support unicode. music files or dir with non-english names wouldn't load up in playlist..
    - I don't know if it's just me, number of times, it doesn't find my music path.. Throws you out somewhere in C drive.... I had to exit and reload RR to get to my list...
    - oh one more.. ^^ I know you are all about keep things in simple, but it would be nice to incorporate VIS right on top of that album art in audio player and make it transparent... ^^
  5. #125
    Dec 2007
    ok... i followed ur guide in help folder.
    I got autoit error in loading RR.. Line -1: Error: The requested action with this object has failed.
    This probably is not a skin issue, but embedded art doesn't work... it flashes jpg file for a .2 sec and dispears.... Are you experiencing this too?
    -- update..
    tags work great... rate still not working...
  6. #126
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by brandensin View Post
    -- update..
    do you have active winamp and winamp 5.13
  7. #127
    Dec 2007
    yes... winamp 5.13 i had.. and installed active winamp.. one thing i wasn't too clear from the instruction.. was this...
    Next go into Winamp and activate the Media Library, and add your music to it.
    -- I don't know exactly what it means...
    IMPORTANT : Make sure you disable "ONSONGSTART","" and "ONSKINSTART","" in RR's ExecTBL.ini, the one in RR's root.
    -- i don't see them so, no need to disable..
  8. #128
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    right ok
    open Winamp on its own, right click on the top bar select media libary, if have never done this before it should give you a popup asking to search for music,select your music folder and go thats done.
  9. #129
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    something is not letting the script Sync_Lib.exe set your music library as the default. you can do it manually do this.
    open winamp, Ctrl + P>>MediaLibray>>Watch Folders>>Add Folder(add your music directory)>>Rescan now
  10. #130
    Dec 2007
    sweet... that did the magic guys.. Thank you so much... For one more clarification.. Let's say i rate my songs 4 stars... That shoud save the songs under 4star playlist in playlist folder, right? Then i should able to play that list any time from that folder, correct?
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 01:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 03:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 11:59 PM
