Page 17 of 41 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #161
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Quote Originally Posted by Stoney View Post
    Can someone help, im having problems. When i click backgrounds, roadrunner runs at 98% and nothing happens. Ive read through this thread and tried everything suggested but i still cant get it working.
    Cheers
    I've looked thru to RR.ini, and it looks good to me. Do you have ilists activated on TEK2. I ask because on a test system I had here, wen I had iLists turned on the system would freeze because I did not have DirectX installed.
    Does the freezing happen on any of the other lists ?
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #162
    Jan 2008
    Quote Originally Posted by Valheru View Post
    hi Lithje,
    1. are you talking about the iLists ? if not then I have the same problem with the playlist and I'm not sure of the fix. I have asked on this forum but got no answers.
    2. I have my RR volume set to "master" and the volume works correctly - as it should. Try changing the RR setting to master.
    3. The "light bulb" was actually for coverflow intergration (browse by cover) but it's not implemented in the skin yet. So this button does nothing.
    4. you need to edit the GPS_Menu.skin file to change the program the is called from within the skin so that it calls your version of destinator.
    5. I don't actually use the radio func at all - no usb radio on my setup. so I can't offer much hel pfor that one I'm afraid.
    Hope these answers help in some way !
    1. I don't even know what the iList is.. I'm talking about de list you see when you push the 'music library' button. You can choose 'up' and 'down' and then you get the rolling effect.
    2. I set it back to 'master' and it works great. When I installed the skin the other lines were acting weird. That's why I set it to 'all lines', but that seems to be ok now.
    3. haha ok I didn't know that. Something for the future!
    4. I really don't know how to edit that skin-file.. I am new whit editing. Have to read more about it first.
    5. Don't ask how, but if I'm lucky then tomorrow I'm gonna buy me a RadioShark 1 !!
    I called almost every shop in Holland, and now I found one which has one Radioshark 1 left! If everything goes right then I got it monday. I hope so, all my radio-problems will be solved!!
    Three days ago my PC kept starting up.. it didn't stop! Searched the web for two days and I found the answer.. my 'wireless USB' was giving it a hard time. Glad I got it fixed!
  3. #163
    Jan 2008
    I don't know why, but my reply isn't posted again..
    anyway, I just got hold of a RadioShark 1.. I'm jumping around the room here!
    How does it work with this skin? When I get it at home (probably monday), do I just install it on my PC and then set RRconfig to 'Radioshark' and that's it? Or do I have to edit something..?
  4. #164
    Jul 2007
    Ireland
    I would imagine so ... just install the radioshark and get it working in windows first - then config RR to use it and that shold be it ...
  5. #165
    Jan 2008
    To come back at your other answers:
    1. I don't even know what iList is.. will look it up on the forum and check if it is turned on in RRconfig.
    2. RR volume set to 'master' works! I had problems with the other lines but that seems to be gone now.
    3. haha so that's what the light-bulb is for.
    4. I don't even know how to edit a GPS_Menu.skin file.. Have to look that up!
    5. RadioShark 1 is on the way! Lucky man here!
    Thanx for the quick reply!
  6. #166
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    ilist
    Quote Originally Posted by Lithje View Post
    if you have the audio files listed in the browser libary, just to test switch ilist off using the ilist button in the skin forgot where it is i think its in the skin set up not sure any way look for it switch it and go back to the libary if the text is still showing then ilist is working for you,it will look different to most others as Val has gone the none graphic's way. if anything download new age skin which has graphic ilist in it and try that to see if ilist is working for you ,also what version of rr are you using.
    open Exectbl file in the skin folder and change the path to your Destinator.exe. look for this line
    "GPSDEST","LOAD;Destinator.skin;Sat Nav;c:\car\destinator\destinator.exe;Destinator"
    if that dose not work for try this 1
    is open EXECtbl file and go to gps stuff and put a /, at the beginning of each line, save,now open the menu skin in notepad,change the gps button ,
    B14,335,359,130,235,"BYVAR;GPSCHOICE;GPS<<GPSDEST< <GPSAUTO<<GPSIGV4",@GPS@
    to
    B14,335,359,130,235,"GPS"
    this will now call the gps settings in thrr config and run d6 for you.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #167
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Tag for later.
    Waiting for XM support
    I would be all over this if it had an XM screen, it is without a doubt one of the slickest, cleanest skins I have ever seen. Excellent work, really.
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  8. #168
    Jan 2008
    Quote Originally Posted by carputer1 View Post
    to
    I think I am using the 09-09-2007 version.. downloaded it 2 weeks ago and did a fresh install. I will check that and run the RRupdater, but I think that was the latest.
    Thanx for the editing support. I haven't got time to test it untill sunday.. I will let you know if it worked! Will the same work for MapMonkey? I gues it will.. just gonna try it!
  9. #169
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    for map monkey just change the rrconfig, and use "gps" as your launch button from the menu skin.
    as for your rr it sounds like a old 1 download the attched and try that ,but back up the rr.exe you have now before running the attached.
    Attached Files Attached Files
  10. #170
    Jul 2007
    Ireland
    Quote Originally Posted by Jistari View Post
    Tag for later.
    well... just so you know - both XM and Sirius screens are on the way. stay tuned !
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 01:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 03:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 11:59 PM
