Page 18 of 41 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #171
    Jan 2008
    I spend the whole day in my car and this is where I am..
    1- when I press the iList button it says 'iList .. on' but when i press it the next time it says that again. Shouldn't that be 'iList .. off' ?? So I still got the problem with that one missing line in the 'music library'
    2- I'm from Holland so iGuidance doesn't work for me. I had the old version of Destinator (3) with MapMonkey but I couldn't find upgrades anywhere. Then I read a lot about DestiPLUS with Destinator PN.. and I got it to work!! It took me a few ours but I can navigate now. Only the embedding doesn't work right away. First I don't see the upper black bar from Teknik2, but the 'off' button of DestiPLUS. When I push that it ask you if you want to exit, then I press 'no' and then it embedded right.
    -The 'keyboard' funcition in DestiPLUS doesn't always show up.
    -When you acces the 'adres' menu, the input is way to small.
    could these problems have anything to do with this skin? Can I use the iGuidance skin or something?
    3-when I use navigasion, RR slows down.
    4-I miss a slider in the audio-menu. I often play music-mixes of 70/80minutes. Forwarding takes to long.. Anything in the future with that? Somebody else mentioned it before in this thread.
  2. #172
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    hi mate,
    1. try using the "ilists off" button to turn off the ilists and see if you still have the one line missing problem.
    2. & 3. rr should not slow down in navi unless the pc you are using is very old. destiplus is using a different window name from "destinator" that's why it diesn't embed properly the first time, this will happen no matter what skin you use. search the RR forum for links to embed destiplus.
    4. I will look at adding a slider on audio screen in the next release ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  3. #173
    Jan 2008
    1. I got an 'iList on/off' button and everytime I press it, it says 'iList are on'. Nomather what I do, it's always 'iList are on' and NEVER 'iList are off'. Can I edit it somewhere to 'false'? I looked in the rr.ini but couldn't find anything. And if the iList is on, the missing line in the 'music library' is still gone.. The 'rolling-effect' is just 1 line to long.
    2/3. I think I found some answers in the settings.. The weird thing is that if you run DestiPLUS standalone it works fine, and if je run it in RR then it's not running so good anymore. Functions get lost and stuff.
    4. a slider would be great!
    Now I got anohter problem (they just keep coming )
    I just installes RR on my PC here behind my desk to test some stuff before I put it in the car. Now I have got the same problem as described in post #112.
    The answer from Treetop777 in post #113 doesn't do anything.
    Thanx again
  4. #174
    Jul 2007
    Ireland
    press and hole the "iLists" button for about 2-3 seconds and iLists will turn off. A lot of TEK2 buttons have second functions that happen only when you hold down the button. iLists are one.
    Check the settings for the background path as outlined here ...
    ** NOTE ** : Make sure that your RR.INI setting for the background path is correctly called "backgroundpath", and not "background". This is required to make the background selector work correctly. Needs manually editing of the RR.INI file.
    what might be quicker is to copy the rr.ini and skin.ini files from your car to your other pc ...this will fix the problem. your background path is just not set right on the dektop pc.
  5. #175
    Feb 2002
    right, ive tried turning ilists off and that didnt solve the background problem. Im not to fussed with this cos i only use 1 background anyway.
    New problem when i close rr, rate.exe and sync_LB.exe are still open and if i open rr again i get multiple instances. The only way i can get rid of them is end process.
    Any ideas?
    thanks
    also i have the same problem with the browser missing out 1 line when scrolling, seems like directory list is too small?
  6. #176
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Quote Originally Posted by Valheru View Post
    well... just so you know - both XM and Sirius screens are on the way. stay tuned !
    "You da man" (dragonlord . . .was that Fiest ? or Rosenberg? . . .cant remember? Ah yup (Fiest) . . .Ashen Shugar )
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  7. #177
    Jul 2007
    Ireland
    Quote Originally Posted by Stoney View Post
    Any ideas?
    thanks
    can you post a screen shot of exactly what you mean about the browser ?
  8. #178
    Jan 2008
    Aaaaaaah that's how iList works.. will try it tonight. Then I can also show you some pictures
    The settings for the background in rr.ini are correct --> backgroundPATH. Also picpath is forwarded to the backgroundfolder as what treetop777 wrote. I will try the RR.ini and skin.ini from the car tonight.
  9. #179
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    cahange your background path
    Quote Originally Posted by Lithje View Post
    to backgroundpath=
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #180
    Jan 2008
    Quote Originally Posted by carputer1 View Post
    to backgroundpath=
    Yeah I know, but I will checked tonight to be sure.. tnx!
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 01:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 03:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 11:59 PM
