Page 21 of 41 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #201
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    9 times out of 10
    Quote Originally Posted by Xoxol View Post
    I love the v2 of this skin, but here is my problem. After installing the latest version on RR, Teknik2 skin doesn''t work properly. The background doesn''t load at all and all the buttons load only after I scroll over it... Don;t know what''s that ( Anyone else has this problem?
    its your background path, check rr.ini,and the skin.ini make sure they are pointing at the backgrounds folder, this will be my 1st start.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #202
    Nov 2007
    damn... I new about rr.ini editing but didn''t know about skin.ini.
    Editing skin.ini helped. Thanks a lot!
  3. #203
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    You need to open the file called "RR.INI" and look for a line "background=" and change it to be "backgroundpath=". this should point to the directory where all of your background images are located ...
    If you are using a default RR install, this would be (for TEK2)
    c:\program files\roadrunner\skins\teknik2\backgrounds\
    hope this helps.
    valheru
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  4. #204
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Valheru View Post
    Make sure that your RR.INI setting for the background path is correctly called "backgroundpath", and not "background". This is required to make the background selector work correctly. Needs manually editing of the RR.INI file.
    Are you talking about this section?
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\Teknik2\
    nightskin=C:\Program Files\Road Runner\Skins\Teknik2\
    transition=-1
    background=To set path, Click --->
    TransitionTime=0.2
    I'm getting this (image below) and when I wave the mouse over the screen, images appear.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  5. #205
    Jul 2007
    Ireland
    yes indeed ...
    change the line that is
    to be this line
    backgroundpath=c:\program files\roadrunner\skins\teknik2\backgrounds\
    and then you need to find the file called "skin.ini" which is in the "Teknik2" folder. In there there should be a line that says ..
    BACKGROUND=C:\Program Files\RoadRunner\Skins\Teknik2.2\Backgrounds\\Vista1.jpg
    This will then have a background image set for TEK skin ... and then you'll be able to change the background from Config -> skin Settings -> backgrounds inside the skin.
    If you want to add new background images, save them to the folder c:\program files\roadrunner\skins\teknik2\backgrounds
    Images should be 800x600 or better quality.
    ... valheru.
  6. #206
    Jun 2004
    South-Central PA
    Cool, got it, with some changes:
    backgroundpath=c:\program files\road runner\skins\teknik2\backgrounds\
    (added the space between Road Runner. Like road<space>runner.
    And:
    BACKGROUND=C:\Program Files\Road Runner\skins\Teknik2\Backgrounds\Vista.jpg
    Thanks for your help.
  7. #207
    Jul 2007
    Ireland
    glad to have it working for you ...
  8. #208
    Apr 2007
    France/Paris
    Hi Valheru,
    Is it possible to use an external GPS ?
    I use Sygic Drive and it does not load in your skin.
    Thanks in advance
  9. #209
    Jul 2007
    Ireland
    yes indeed TEK2 will support external GPS.
    Firstly, you need to configure RR to use the GPS menu.
    Once you've done that, you will need change a line in the file ExecTBL.ini as follows ..
    "GPSDEST","LOAD;Destinator.skin;Sat Nav;c:\car\destinator\destinator.exe;Destinator"
    change the "c:\car\destinator\destinator.exe" to be the path of your GPS program and then change the ";Destinator" be be the window name of your GPS program window - leave in the ";".
    you will also need to change the file "Destinator.skin" line that reads ..
    A01,0,60,800,540,000,"Destinator"
    and change "Destinator" to be the name of your GPS program window.
    Now after all this, when you press SatNav on the TEK2 menu, you should get the GPS menu. Now if you select Destinator, your GPS program should work. Pressing anywhere on the top black bar of the GPS screen will return to the TEK2 menu.
  10. #210
    Apr 2007
    France/Paris
    Thanks I'll try this tonight And let you know if this help.
    Do you plan updates on this skin?
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 01:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 03:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 11:59 PM
