Page 23 of 41 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #221
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Quote Originally Posted by Cob94500 View Post
    Hi Valheru,
    The sygic tips is working great but when I clic on GPS I always have the choice beetween all gps.
    Isn't there a tips to have sygic directly when i clic GPS?
    I agree with IMI i don't need radio I prefer to have the phone button on 1st page and radio on the second.
    Last you asked me what is missing, i think it could be cool to have an integration of odb diag software.
    Thanks again for this great skin
    if you use the rrconfig program you can set RR to use a single GPS program, in this case your sygic program, rather than selecting from a GPS menu. Once that is done, just change the line
    B14,331,355,135,240,"BYVAR;GPSCHOICE;GPS<<GPSDEST< <GPSAUTO<<GPSIGV4",@GPS@
    to be this line
    B14,331,355,135,240,"GPS","GPS"
    that should do it ...
    to change the radio with the phone options you can do this ...
    in the file menu.skin replace the line
    B13,178,355,135,240,"BYVAR;RADCHOICE;MENU;Radio_Me nu.skin<<XM<<RADIO<<SIRIUS",@MENU;Radio_Menu.skin@
    with this line ...
    B13,178,355,135,240,"FREEFONE","FreeFone"
    and in the menu2.skin file, replace the line
    B10,329,355,135,240,"FREEFONE","FreeFone"
    with this one ...
    B10,329,355,135,240,"BYVAR;RADCHOICE;MENU;Radio_Me nu.skin<<XM<<RADIO<<SIRIUS",@MENU;Radio_Menu.skin@
    that will change the menu options, but not the icons, as the screens would need to br redrawn for this ...
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  2. #222
    imi
    imi is offline
    Newbie imi's Avatar
    Jan 2005
    I have resized the screen to 800 x 500 - and this is what an embedded application like sygic looks like?
    Any ideas?
    BTW: I fixed the hibernation issue with shutcontrol (FANTASTIC APP)
  3. #223
    imi
    imi is offline
    Newbie imi's Avatar
    Jan 2005
    Quote Originally Posted by carputer1 View Post
    if you want the gps button to go directly to your sat nav set it up in RRconfig,change the menu.skin button to GPS , and change the Destinator.skin to External_GPS.skin
    this should do it.
    Just tried this..and yes it works...however the sygic app is no longer embedded into the skin.
  4. #224
    Jul 2007
    Ireland
    if you have sygic working as the "external gps" option and you have also renamed the "destinator.skin" file to be "exterlan_gps.skin" ... then you wil need to change the line inside the "external_gps.skin" file that reads ...
    A01,0,60,800,540,000,"Destinator"
    to be ..
    A01,0,60,800,540,000," <your GPS program window name> "
    and if your screen resolution is 800 x 480 you will need change the co-ordinates on the line as well to be ...
    A01,0,60,800,420,000," <your GPS program window name> "[/B]
  5. #225
    Apr 2005
    Budapest/Hungary
    Quote Originally Posted by Valheru View Post
    Selecting the HD radio option will bring up the AM/FM radio support as they are both integrated into a single skin.
    Thanks, it works, but with a little problem. I see that RRHQCT.exe loads, and I see then the skin's radio page, the frequency, the stations, etc, but only for 2 seconds. Then I see again the main screen. Meanwhile I hear the radio and when I click to the radio button I see again the radio screen, but only for 2 seconds. Maybe something puts back the focus to the main screen. I tried with my home pc and carpc also, the result is the same. Is it OK, or did I something wrong?
    Morex 3688 -|- VIA Epia MII-12000 -|- 256MB RAM -|- 40GB Samsung 2.5" HDD -|- Panasonic slim combo -|- M1-ATX PSU -|- Lilliput 7" Touchscreen TFT built-in to middle console
    HQCT -|- Avermedia DVB-T -|- Phonecontrol -|- Bluetooth GPS
  6. #226
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    this is something
    Quote Originally Posted by Flex View Post
    that needs to be worked on, as i know val has no HQCT to test with , have a look at the forums about HQCT and see if there's any info about Setting this up , it may help in getting a skin sorted or it maybe somthing you can do yourself. Have you had this working in any other skin other than Teknik, if so what skin did you get it working in may help.
    I'm sure that Val will look into this for you,but any help you can provide will speed a result up for you.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  7. #227
    Apr 2005
    Budapest/Hungary
    You don't need any hardware, as I don't have any radio hardware with my home PC. I selected HQCT at rr.ini, then I started RR with Teknik skin, pushed the Radio button and there is the radio skin - but only for 2 seconds, then switches automatically to the main page.
    I tried the same with my carpc (there is the HQCT hardware), but the result was the same. Also the same when I select HD radio at rr.ini, it seemt this is the HD radio skin's problem. Works perfectly, but I can't see the radio skin
  8. #228
    Jul 2007
    Ireland
    hey flex ...
    as carputer1 says i've no way of testing HQCT - to be honest at the moment I'm not even sure what it is .. need to do some searching.
    one thing you might try is this ...
    in the file "ExecTBL.ini" in the TEKNIK2 folders .. comment out the line
    "TIMER","SETINDBYLABEL",Radio_Player.skin which is located in the HD Radio Support section ... this is used by HD radio to update indicators every second .. this might be the rason that the radio skin dissappears after one or two seconds ..
    I'll look into the HQCT stuff and if I find anything else I'll come back to you ...
    one other thing, have to got HQCT working on any other skin ? if so can you let me know ..
  9. #229
    Apr 2005
    Budapest/Hungary
    hey flex ...
    HQCT is a car specialized radio tuner product, it has an mp3car.com thread here
    RR has embedded support for this unit, look for the HQCT folder at RoadRunner main folder, RR starts rrhqct.exe when you push the radio button in every skin. I used DigitalFX skin before and worked perfectly, this is the first time when I see in a skin that the radio skin disappears after 1-2 seconds.
    Unfortunately, the uncomment doesn't work, the result is the same
  10. #230
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Visual in Audio_Player Skin
    ok i have added Visual's to the player skin, using DFX2 code.
    on the album art tap the left side to satrt Vis and left side to move to the next Vis.
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 01:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 03:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 04:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 01:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 11:59 PM
