the files are available on post#1 of this thread. as for updates ... once I get some time to develop them I'll post them here ...
I m just wondering how i can get the update files? This skin looks awesome.
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
Has anyone managed to find the cure for this.
I use a D-link 100 controlled by Radiator.
I would like to set it up in Teknik2 but the screen does not display long enough for me to do anything
Hi, I'm using iguidance 4.0 and v2.0 of the skin. The buttons at the top of the iguidance screen don't work, well the home button does but thats the only one. Does anyone know how to fix this? Thanks
Also, is there anyway to just have the GPS button load iGuidance instead of having u choice from the three GPS programs?
one other thing...whenever iGuidance launches the task bar covers up the bottom of iGuidance...is there any way to fix this?
Look into the GPS_MENU.skin and copy this line
"SETVAR;GPSCHOICE;3||SAVETOSKIN;GPSCHOICE;3||GPSIG V4","IG4"
Then open MENU.skin and paste the over this line.
"BYVAR;GPSCHOICE;GPS<<GPSDEST<<GPSAUTO<<GPSIGV4",@ GPS@
Now you start IG directly by pressing the GPS Button.
The HOME Button runs a Autoit script as the others using the SENDKEY Command. They should work fine as they do on my test machine.
thanks for the help....but the buttons at the top still do nothing when pressed. I did get it to launch with out the choice menu though.
i looked in the iG script folder and there are only 2....home and adress...should there be more
Try to run RR with the technik skin and go into GPS. when iG4 is running, click on the map to give iG the focus,use the keyboard and hit the number "3" button. It should change the view fron 3D to 2D. Then you know the keyboard shortcuts are working.
one other thing....how do I change the time format from 24h to 12h...thanks again
