thanks for the heads up mitch ... which version of screenlock did you use, so that I can update TEK2 ?
ah ha see val its not just me who needs a new computer Mitch's "Cancel" dose'nt work either lol....
The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
i ended up dropping in .5
which might be what you send out with tek2
but i already had it in my RR dir, from some "other" skin
so i didnt do anything...
other then drop ur skin into my skins dir, and switch to it
mitch
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Hi,
what software do you use to creat the backgrouds?
I have loads of other menus I would like to add etc but I can not find how to creat the same style menu buttons you use.
the skin is designed using Paint.NET for the main screens and MS Visio for the popups.
Hi,
I have paint.net but hav no idea how to do the desighn you have for the buttons etc, is there a good place to look for a guide etc?
Looks like the buttons were created using a reflection plugin in PDN.
http://paintdotnet.forumer.com/viewt...hp?f=16&t=2520
@Valheru: I gotta say, I'm loving v2... miles ahead of v1.
The "white" button backgrounds were drawn in MS Visio, and imported into PDN. The reflections are manually put onto the screens by simply flipping and shrinking the "white" squares, and then changing their transparency. The blue and red circle icons are stock icons I found on the internet.
Valheru, what is function pf photo button?
If i press the button, i'm not see anything (see pic).
How to configure photo button?
tangkas_baru
That button is the "slideshow" feature.
The picture viewer is an external program called imageviewer. To correctly use this program you need to edit the ini file called
"Teknik2\ImageViewer\ImageViewer_Config.ini" and change the line called "Init_Path =" to point to where you have your pictures stored.
