Page 39 of 41 FirstFirst ... 29303132333435363738394041 LastLast
Results 381 to 390 of 408
Thread: Teknik v1.0 & v2.0 - RELEASED ...
  1. #381
    Newbie leeman01's Avatar
    Aug 2008
    Pikeville, North Carolina, United States
    Background problem
    Edited my post about background problems...figured it out. Had to add a space in "Road Runner" in the backgroundpath in skin.ini.
    Awesome skin! Just now getting my carpc put together and great skins make it worthwhile.
    Thanks!
  2. #382
    Oct 2007
    Quote Originally Posted by Valheru View Post
    That button is the "slideshow" feature.
    The picture viewer is an external program called imageviewer. To correctly use this program you need to edit the ini file called
    "Teknik2\ImageViewer\ImageViewer_Config.ini" and change the line called "Init_Path =" to point to where you have your pictures stored.
    Val, thank you for your tips. I like this skin.
    I'm not use radio now. Why you not add camera recording function? I want change radio to camera. I hope you add camera function in next version. Sorry with my bad English. I'm from East Borneo, Indonesia.
    tangkas_baru
    http://www.flickr.com/photos/tangkas_baru
  3. #383
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    I will certainly look at adding camera functionality to the next version ...
    Wow - East Borneo, it's little things like this that make the skining worth while. It's a great buzz to realise someone halfway around the world is using something I created ... thanks for the comments.
    The TEKNIK Family ... Teknik 1 & Teknik 2, Teknik T-3, Teknik v4.0, Teknik-X.
  4. #384
    Sep 2008
    Hello M8!
    I've spend at least 2h joking around this theme and I'm loosing my faith...
    I tried to change command lines (on pg.14) and still does not work...Is there possibility that I have a "wrong" version of RR installed?The icons do not show,and the background does not appear...Please help me with this,because this is the best theme I've ever seen on this site...Can you create it like that DigitalFX,so you simply install it and everything works just fine...Thanks for answering my question,greetings!
    ---P4 2.8GHz
    ---512Mb RAM
    ---40GB HDD
    ---7" Xenarc touch
    ---USB-Cd Rom
    ---VW Sharan 1.9tdi
    Instal---90%
  5. #385
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    It should of set a background temp for you , but looks like it did'nt , check the background paths, in rr.ini found in the rr folder and the skin.ini in the skin folder.
    also make sure you have GDI mode set to fast in rr.ini (RRconfig)
    as for rr version, depending if you use hd or sat radio download the latest version from Mitch found in the stick of the rr forum.
    if you still having problems post your rr.ini here for us to look at . afraid i'm off for a few days .
    wifes birthday , but i'm sure val will sort you out
  6. #386
    Jul 2007
    Ireland
    Quote Originally Posted by Alix View Post
    Hello M8!
    I have a feeling that this might be an issue with the folder name for RoadRunner. Is there a space in the folder name ? If you can tell me what the folder name is where RR is installed and also if you could post your RR.ini file here I'll sort this out for you.
  7. #387
    Dec 2007
    Volume window won't close
    My volume pop-up won't seem to close either. Also the cancel doesn't work. Was a fix ever found?
    BTW.....Love this skin!!!!! considering switching from Streetdeck.
  8. #388
    Sep 2008
    thank you my friends for helping...Now let me see...
    I've no idea about INI files,etc because I've never used those cind of programs...What exacly do I have to send to you,that you can help me?
    Sorry I know I'm very stupid for asking,but I'm young and have no one to help me,beside you...
    Here goes nothing:
    RoadRunner is instaled in C/Program Files/RoadRunner
    rr.ini looks like this:
    [Player Setup]
    player=Winamp
    winamppath=Click here to set path
    hidewinamp=false
    exitmute=true
    [General]
    voice=false
    disableinternat=false
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=false
    hidedesktop=false
    hidedots=false
    gpstime=false
    exitmode=0
    dateformat=Short Date
    timeformat=Short Time
    locale=0
    screentype=4:3
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=true
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=10
    mastervolmap=0
    hibernateaware=true
    forcehibernate=false
    hibernatereload=true
    usbsound=false
    browsertype=0
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    picspath=To set path, Click --->
    [Skins]
    transition=-1
    backgroundpath=c:\program files\roadrunner\skins\teknik2\backgrounds\
    TransitionTime=0.2
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=1
    autoskinmode=1
    [Preload Screens]
    [Music]
    musicpath=Click here to set path
    playlistpath=Click here to set path
    useid3=0
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=false
    visuname=MilkDrop
    scrollmode=1
    circularlist=false
    groupnumbers=false
    resumemusic=0
    audiorepeat=false
    audioshuffle=false
    transparentvisu=false
    opacityvisu=40
    [Radio]
    radiomode=0
    allowallfreqs=false
    radioline=0
    userbds=false
    [XM]
    xmport=0
    xmline=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRIUS]
    srport=0
    srline=0
    srlineinplugin=false
    singleclicksr=false
    srformat=%station% %artist%
    [Video]
    videopath=Click here to set path
    mpcpath=Click here to set path
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videoshuffle=false
    [TV]
    tvline=0
    [GPS]
    mapmonkeypath=Click here to set path
    gpspath=Click here to set path
    gpsname=
    overspeed=55
    gpsport=0
    mappointmap=1
    mapcountry=United States
    mapcity=
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    [IG Native]
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=0
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=true
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=
    weatherunits=USA
    weatherdegress=ş
    localdatacaptureinterval=0
    [Extra's]
    background=C:\Program Files\Road Runner\Backgrounds\WindowsLogoBlue.jpg
    ---P4 2.8GHz
    ---512Mb RAM
    ---40GB HDD
    ---7" Xenarc touch
    ---USB-Cd Rom
    ---VW Sharan 1.9tdi
    Instal---90%
  9. #389
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Here goes nothing:
    All your background path's got to match; decide wether you are going to leave "roadrunner" with or without a space then make all your paths match- and what's with the front and back slashes?? They should all go one way or the other right?
    Also look in the skin.ini within the skin folder for a line like this
    BACKGROUND=C:\Program Files\Road Runner\backgrounds\Anna_kournikova8.jpg
    make it match all your other backgrond paths also.
  10. #390
    Jul 2007
    Ireland
    Quote Originally Posted by treetop777 View Post
    All your background path's got to match; decide wether you are going to leave "roadrunner" with or without a space then make all your paths match .
    Hi Alix .. RoadRunner - with or without a space depends on the folder name where RR is installed. From your post I'm guessing this is "RoadRunner" (with no space).
    So your background path in RR.ini should be ...
    "backgroundpath=c:\program files\roadrunner\skins\teknik2\backgrounds\"
    and
    the setting in the skin.ini should be ...
    "background=c:\program files\roadrunner\skins\teknik2\backgrounds\blue.jpg"
    BACKGROUND=C:\Program Files\Road Runner\backgrounds\Anna_kournikova8.jpg ...
    Treetop .. Nice choice in background images, are you going to post it ????
    Quote Originally Posted by silent76 View Post
    The fix for this issue is to use Screenlock Plugin v0.5 which can be found here in Post #1 ... http://www.mp3car.com/vbulletin/rr-p...ck-plugin.html. Seemingly there is a problem with the version of Screenlock that I bundled with SP1. S just download the new files and overwrite the files in the RR directory.
  1. GATSO Hunter v1.0
    By Engram in forum Software & Software Development
    Last Post: 03-17-2008, 12:31 PM
  2. Rc2 Without Progress Bar???
    By coucouillu in forum Centrafuse
    Last Post: 08-11-2006, 02:49 PM
  3. moto e815.. some progress but more questions!
    By Sonicxtacy02 in forum PhoneControl
    Last Post: 04-24-2006, 03:00 PM
  4. Progress meter not showing
    By Meelobee in forum Road Runner
    Last Post: 07-15-2005, 12:20 PM
  5. GPSSecure V1.0 ToDo Checklist
    By xBrady in forum GPSSecure
    Last Post: 06-03-2005, 10:59 PM
