This is a basic skin for iguidance 4; has the commands that i mostly use but can easily be customized. Just drop the content of the folder into the skin forlder and change the "SATNAV" (main menu) button command to "GPS".
nice work treetop777 ...
if you like I can create a screen file for this with text shadow's etc to match the rest of the skins ...
Hey fantamos ..
Any of the pop up screens have a 5 sec IDL timer on them, such as the volume screen, GPS menu and exit menu ...
Make sure you that all of the files from the "EXTRA'S" folder are copied to the main RR folder before you run the BAT file ... this should enable the tags editor to work. Let me know if not !
I got the editor to work for Artist,Album,song but not for track number or Year. It brings up hourglass like its doing something but doesn't bring up OSK?
you most likely have the original version of the skin ... if you add this file to the skin folder it will bring up the osk for entering numbers. Save it and rename it to "numosk.skin" - I didn't have this in the first release. The version available on page #1 now has this file.
hope it works for you.
Yep that fixed it! Thanks for getting me lined out!
sorry i took this much time to reply
i've been busy the last days
i'm just replying this BEFORE sending u the PM to make it public I won't publish any of your graphic work or code without your permission
I like both designs, but I guess v2.0 is the way to go
if u search a little in the skins subforum u'll find that the iphone like skins are the most wanted around here. and there's no one really out now. just beta and/or previews
[]s
looking forward to seeing your work on this one ... but I'll probably have to learn how to use PS then to keep up with your transparent version !
Hello,
First off i would like to say that you have created a great skin. I would like to humbly request a color changer option coded in? The gold does not go with my interior lights very well. I have a BMW z4 and the lights are a deep red. Thank you so much. Again great great skin.
