Results 1 to 10 of 16
Thread: Resizing gps software failes
    Newbie Phreak Show's Avatar
    May 2006
    Germany, Bavaria, Augsburg
    Greetings,
    here's my problem:
    I use an emulator provided by Microsoft to simulate a Windows Mobile 6 environment. In this environment I want so run navigons pocket-pc software.
    So I created a .ini file under launch and set up the correct information such as window name and path.
    So I start up my emulator with rr, and then cpu goes up like 100% and stays there.
    You can see rr how it's trying to resize the emulator's window to full width, but that doesnt work because it's got a fixed size of 320x240 (greyed 'maximize'-button up right).
    Then I found out something about the launch.skin, concerning the last lines starting with A01.
    I successfully resized other programs, but not the emulator. My problem is atm, I dont know how to calculate the correct sizes.
    I attached a screenshot, you can see the emulator. The total sizes are written to the screenshot, including all parts of the window, i.e. frames, etc.
    Are these sizes correct for use in launch.skin?
    If now, how do I calculate them correct?
    Cheers, Phreak
    Constant Bitrate GuMiSZu's Avatar
    Nov 2006
    Hungary
    You can't resize emulator...
    You can run emulator with specified size... (but IGO use : 320*200 or 640*400)
    Englishlessness :(
    Nov 2006
    Hungary
    oops
    but you can crop the window with Skinbedder...
    Englishlessness :(
    May 2006
    I cannot resize this windows, of course.
    But I do not want to resize it, I just wanna run it embedded, pinned at the upper left corner. My problem is, I dont know the correct sizes to add them in launch.skin.
    So rr keeps on resizing it which crashes the system. I just need the correct sizes and I'll be happy
    Nov 2006
    Hungary
    Make an bigger Embed field (C ) and the rr wont resize is.
    and after maka an screenshoot. and look the picture in an photoviewer...
    Englishlessness :(
    May 2006
    Where can I define such a bigger embedded-field with which kind of syntax?
    Edit:I found out how to define it, but it doesnt work..
    I just need the correct rules to calcuate the window size in pixels...
    Nov 2006
    Hungary
    in the skin file c01,xxx,xxx,xxx, ....
    Englishlessness :(
    May 2006
    As I said, it doesnt work defining this c-field...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You just have to specify the position and size desired for the window with the "A" definition -- C is for clipping the screen.
    Follow this FAQ:
    http://www.mp3car.com/vbulletin/rr-f...in-screen.html
    Then change the A definition to something like this:
    A01,150,100,326,284
    Ride Runner RR's Myspace
    May 2006
    MEDIACAR Skin
    MEDIACAR Alpine "Launch" skin
    /, (B) Buttons
    /, X Y W H CODE TOOLTIP
    B01,401,000,057,071,"PREV",""
    B02,458,000,110,071,"CLOSE",""
    B03,678,000,057,071,"NEXT",""
    B04,735,000,065,071,"EXIT",""
    B05,568,000,110,071,"LAUNCH",""
    B16,751,494,049,080,"PGDOWN",""
    B07,751,414,049,080,"DOWN",""
    B07,751,245,049,169,"APPOSK",""
    B08,751,165,049,080,"UP",""
    B09,751,085,049,080,"PGUP",""
    /, (L) Labels
    /, X Y W H R G B PT FONT CODE TOOLTIP
    L01,019,018,200,022,255,198,000,18,"LCD Display Grid","TIME","LEFT"
    L02,219,018,168,022,255,198,000,18,"LCD Display Grid","DATE","RIGHT"
    /, (S) Selection List
    /, FORE BACK SELECTED SELECT
    /, R G B R G B R G G R G B TRS PT FONT
    S01,244,091,500,479,255,084,000,000,000,000,109,00 0,000,255,198,000,TRUE,18,"LCD Display Grid"
    /, (J) Album Art
    /, X Y W H
    J01,016,090,203,481
    /, (A) Application Window
    /, X Y W H R G B
    A01,100,100,322,261,000,000,000
    END
    Here's the content of my Launch.skin. As I just want to launch that single prog, I dont need a dedicated button.
    I tried lots of combinations under W and H, but it still doesnt work...
    But why
    greetz
  1. AUSSIES!!! GPS software for PDA
    By krbz in forum GPS
    Last Post: 05-26-2006, 06:47 PM
  2. GPS Software with personal P.O.I. Iguidance? Or?
    By claudioita in forum Software & Software Development
    Last Post: 08-17-2005, 03:19 AM
  3. GPS Software to use.
    By vxcarpc in forum GPS
    Last Post: 03-30-2005, 03:03 AM
  4. Best GPS software for carputer?
    By dazuck in forum GPS
    Last Post: 03-10-2005, 09:52 AM
  5. Wtb: Gps Software And Gps Mouse!!!!
    By HitmanZ in forum Classified Archive
    Last Post: 08-03-2004, 09:56 PM
